0 oil pressure
Old Feb 1, 2006 | 09:55 AM
sean1997ws6's Avatar
0 oil pressure
I was just wondering if there is any other history of this with you all. I was idling at a red like when my oil pressure guage dropped to 0. i have a mechanical guage to which also read 0.The pump is a Melling high volume that has about 9,000 miles on it from the re-build. its prob the pump just took a **** on me but I was just seeing if anyone has ever had that bolt(pin) break or anything like that.thanks.
Old Feb 1, 2006 | 01:09 PM
OBE1 95Z28's Avatar
Re: 0 oil pressure
Not uncommon for the pickup to detach from the oil pump and fall down into the oil pan.
Old Feb 1, 2006 | 08:09 PM
396D1SS's Avatar
Re: 0 oil pressure
i always weld my pick up's on
Old Feb 1, 2006 | 08:57 PM
Re: 0 oil pressure
Yea I lightly tacked it but did wanna over do it.
Old Feb 1, 2006 | 09:21 PM
1racerdude's Avatar
Re: 0 oil pressure
Setting still if ya had no pickup it wouldn't matter ya would still have pressure if it was full of oil.Sounds like ya chewed up the oil pump drive gear that runs off of the cam or the plastic broke and spit the gear out.
Old Feb 1, 2006 | 09:23 PM
Re: 0 oil pressure
Thats what i was afraid of. do you know where i might be able to get those parts?
Old Feb 1, 2006 | 09:27 PM
1racerdude's Avatar
Re: 0 oil pressure
Chevy dealer or junk yard. I wouldn't put a used one in it. They are about 25.00. Are ya sure your cam didn't call for a bronze gear?
Old Feb 1, 2006 | 09:29 PM
Re: 0 oil pressure
no honestly im not sure.
Old Feb 1, 2006 | 09:40 PM
1racerdude's Avatar
Re: 0 oil pressure
If the gear turns out to be the issue,I would check before putting in a stock gear.
Old Feb 1, 2006 | 09:46 PM
Re: 0 oil pressure
where can i get a new bronze gear
Old Feb 1, 2006 | 09:56 PM
1racerdude's Avatar
Re: 0 oil pressure
Ya have to get one for the smaller dia of the plastic oil drive. Comp,MSD,Crower one should have one if needed. I wouldn't run one unless it's needed.
Old Jun 2, 2006 | 03:28 PM
Re: 0 oil pressure
turned out to be the dummy gear where a normal distrib. would be. it was grinded all the way down.
Old Jun 2, 2006 | 05:29 PM
1racerdude's Avatar
Re: 0 oil pressure
Well your cam is most likely gone too. Pull it and see,then get the right gear for the next cam if it's a replacement cam
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
