0-60 Gear Shift
Old Nov 18, 2003 | 03:07 PM
andrec's Avatar
Cool 0-60 Gear Shift
If you want to drive 0-60 as fast as possible with a Camaro Z28 (LT1, M6, Stock) -
At which speed/RPM are you supposed shift gears?
Old Nov 18, 2003 | 03:12 PM
scyzoryk's Avatar
what mods (cam?? 1.6rr??) what gears (stock, 3.72, 4.10??)....If stock LT1 you should shift at 5600 (after that the power drops!!!!)
Sebastian
ps. The gears/tires will be the best mod for you!!!
Old Nov 19, 2003 | 03:32 PM
andrec's Avatar
Arrow
So what is the maximum speed at each of the six gears? (Aprox.)
Old Nov 19, 2003 | 03:47 PM
scyzoryk's Avatar
First of all don’t count 6th gear (it is overdrive, just for the cursing)...Depends on what kind of gears you have (3.42, 3.73 4.10) the speed will be differed...Are you stock?? If you are stock your 1994up M6 can probably has 3.42 gears…Just go to http://www.f-body.org/gears/ and you will have all answers…
jb4xx
Feb 2, 2015 10:00 PM
blac94Z
Jan 12, 2015 05:44 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
Nostang 96z
Sep 10, 2002 08:54 PM
