0 for 2 on Pass. side manifold bolts!!
Old Apr 3, 2004 | 04:35 PM
95RagtopTA's Avatar
Angry 0 for 2 on Pass. side manifold bolts!!
I'm in the middle of a head/cam swap and I'm working on getting the passanger side manifold off. The drivers side was cake, just PB blasted it the night before and the bolts came right out. I soaked the passanger side last night, went to remove the 2nd from the front and SNAP . Got under the car, tried the 3rd from the rear--started out good and SNAP . I'm going to soak the other 4 again and hope my "luck" improves.
Assuming these are breaking flush/in the head, can someone tell me the best way to get the bolts out after I remove the head? I've read that "easy outs" can also break. If you have any "tricks" on how to use them, please let me know. Thanks
Old Apr 3, 2004 | 09:29 PM
95RagtopTA's Avatar
Ok, finally got the passanger side manifold off--major PITA. As it turns out 1 bold is sticking out a good bit (the head just snapped off), the other bolt only has 1+ threads showing. For the first bolt, instead of using vise grips, isn't there something I can thread on the bolt to help back it out? Not sure what to do about the second one. Any help would be appreciated....
Old Apr 3, 2004 | 10:29 PM
Spinner's Avatar
You can spot-weld a nut to the top of the bolt and try to use that to back it out.
Old Apr 3, 2004 | 10:41 PM
97WS6SCharged's Avatar
What is it about cold weather and snapping bolts? The only bolts I've ever broken down here in sunny, warm Florida were a couple of head bolts on a friend's near 30 year old 240Z (fortunately I was taking them out). It spent many years in Michigan before his dad brought it down here and gave it to him.
DirtyDaveW
Dec 1, 2016 05:37 PM
maybe2fast
Mar 16, 2015 09:45 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
Jul 4, 2005 05:00 PM
