*Urgent* How do I break loose the flywheel bolts?
Old May 15, 2003 | 12:23 PM
94 CAMRO Z28's Avatar
Engine just keeps turning and I dont have air tools to break them loose. Any tricks that you guys have use?
Aaron
Old May 15, 2003 | 12:27 PM
mike95z28
Guest
Posts: n/a
I managed to get a breaker bar on there and had a friend hold the flywheel so it wouldn't move. It would move slightly but the bolts finally budged off.
Anothe method is to have a friend hold a wrench to the crank pulley so as to keep the flywheel from moving.. then getting the flywheel bolts off that way.
Old May 15, 2003 | 12:30 PM
To bad im by myself on this job. Im thinking if I wedge a piece of wood against the floor and the flywheel that maybe that will keep it from turning.
Aaron
Old May 15, 2003 | 12:35 PM
HungryT/A's Avatar
Have someone help keeping the harmonic balancer from turning with an extension.
Just my $0.02
Old May 15, 2003 | 12:36 PM
xxsaint69x's Avatar
wedge something between the flywheel and the pan.
Dave C. '97 Z28's Avatar
There is a tool you can buy specifically for this purpose. It's pretty cheap and looks like a big screwdriver with an arm attach near the bottom. You hook it on a tooth on the ring gear and then stick the screwdriver tip into another tooth and then it becomes a handle to turn the flywheel or just hold it in place to tighten or loosen.
The other thing you can try is to turn the flywheel so the bolt you are loosening is on the other side from where you are trying to turn it from. This will give you more leverage on the bolt, but not on the crank because you're pushing back across the lower part of the flywheel compared to the bolt.
Good luck,
-Dave C. '97 Z28
Old May 15, 2003 | 01:01 PM
Well I got the flywheel to stay put but now the bolts are so tight that I still can't get them loose. Im off to go buy a big breaker bar but still, the the 12pt. socket I have was starting to slip and round the bolts slightly. So I dont know if its gonna help or not but I guess we'll see.
Aaron
Old May 15, 2003 | 01:09 PM
I could be mistaken, but I think flywheel bolts are reverse thread.
-Dave C. '97 Z28
Old May 15, 2003 | 01:20 PM
will62085's Avatar
no they are not reverse threaded...i did what was said earlier, get the bolt u want to loosen at the top of the flywheel (by turning engine) and put an end wrench on it vertically coming down...and just go at the wrench with a hammer..this gives u leverage on the bolt, but not on the flywheel
Old May 15, 2003 | 01:39 PM
cool..
yea, I couldn't remember exactly from when I did mine if they were reverse or not, but I remeber they were on there about 70FtLbs worth.
Glad you got them off...
-Dave C. '97 Z28
Old May 15, 2003 | 01:48 PM
Aaron
Always use a 6 point socket for high torque bolts. It's good insurance. If you think it's hard to get out now, wait until you strip the head.
Use a rag wedged between the flywheel and the housing to keep the flywheel from turning.
Old Jan 22, 2005 | 01:08 PM
slp223's Avatar
Re: *Urgent* How do I break loose the flywheel bolts?
I had to pull out a stirpped one last night only took 2 1/2 hour to drill and grind it out.
Old Jan 22, 2005 | 01:52 PM
StickMaster's Avatar
Air tools work great, lol. got those flywheel bolts off in 1 zzzzzzzup 2 zzzzzzzzup 3 zzzzzzzzup 4 zzzzzzzup 5 zzzzzzzzzzup. how ever long it takes you to read that.
Old Jan 22, 2005 | 03:30 PM
GreenDemon's Avatar
Yep the air tools are great for breaking stuff loose. Next best thing would be a mallet. Just hold the ratchet or wrench steady and start tapping. It will give way eventually, even if you have to work it back and forth.
Victor Lamb
Aug 26, 2017 02:52 PM
KYWes
Apr 3, 2015 07:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
MJ_Z28
Aug 7, 2002 07:15 PM
