*update* 383 Le2 A4 Issue
Old May 23, 2006 | 08:14 PM
  #16
ZZ17IROC's Avatar
Re: *update* 383 Le2 A4 Issue
Originally Posted by TQdrivenws6
Get your IAC counts to ~40 at hot idle and then slot your TPS so you can get it to be about .5v at closed throttle. If this isn't adjusted properly, the car will do exacly what you are describing.
What he said. Give the car what it wants, not what you thing it wants. The ecm does what you tell it to do, so the ecm learns very little on its own.
And yes your IAC counts should be around 20 to 40 counts with the car in gear, meaning you need to put a load on the motor. Adjust the throttle blades with the adjustment screw on the TB a 1/4 to 1/2 turn at a time start the car and allow it to go into closed loop then put car in gear and monitor IAC counts and TPS volts. Also adjust TPS to .56 volts after every adjustment, your idle will be a little higher than stock. But you have to remember your car is not stock.
What you are doing is; compensating for the cam over lap (reversion). The intake and exhaust valve being open at the sametime. So stock idle settings will not work to good and that's why your car shuts off when you put it gear. I hope this helps!
Old May 23, 2006 | 09:37 PM
  #17
playa7970's Avatar
nice..... now im slowly learning how to do this **** thanks guys !!! keep em commin lol
Old May 23, 2006 | 09:59 PM
  #18
Honda Hunter's Avatar
Fug. It's not as easy as everyone makes it seem. Ill try again but my iac's start off so high and the lowest I ever got them was 39. Then I screwed up and it shot up again. Then they started in the 100's and slowlly worked thier way down to the 60's and stayed. I hate this car.
Old May 23, 2006 | 10:39 PM
  #19
playa7970's Avatar
lol right??? u think you have it then your right back to where u started sometimes i think maybe i should have left it stock and sold it
Old May 25, 2006 | 11:27 PM
  #20
playa7970's Avatar
Well i Finally found the culprit to my idle issue the damn MAF connector harrness was pinched can runs great now does not cut out and does not run rich anymore time to break her in........
tnorm077
May 23, 2015 09:10 PM
Drtryder
Apr 22, 2015 04:17 PM
Bignasty85
Mar 3, 2015 04:05 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
