With $10,000 how fast could I run??
Thats total i ll put the invoice on if you dont beleave me. I just got a scanner today time to figure it out anyway. 3800 for parts and labor/machine work and 3.6k for blower. 600 for headers and thats it. Let me dig the invoice up.
Originally posted by Xride
15000 CAN = 10317.33 USD
hence the title, $10,000
Originally posted by Gripenfelter
First off Tony meant $15G cdn.
Fast Caddie: Forged 383 for $3500?? From who?
Nick has excellent prices on his stuff.
www.nu-tekmotorsports.com/new_page_3.htm
Say $2500 (AMERICAN) will cover the purchase of the rotating assembly and caps, a local builder here charges about $1K for machine work, assembly, and other little parts/pieces/things (has already done one engine for my brother). Plus there was enough overestimation in my "budget" to make up for some little things that were unaccounted for. Not trying to be perfect with the numbers, but it depends on who's buying.
ss valves $10 each
chain gears $88
sir Ibeam rods $230
srp 8.50 to 1 $453
035 molly rings $109
eagle forged crank $400
roller cam$240
lifters $135
Retainer locks $135
sfi flywheel $59.35
comp pro mag rockers $280
push rod $88
Gaskets $150
total2323.95
labor
3angle v/jo $125
surface $53.03
port polish $375
r&r pistons $52.56
boil block $35.38
Boring 145.44
in cam brgs $32.59
freeze plugs $25.25
bal v-8 $225
LG block *** $400
misc labor $80
Total 1538.84
Thats just how my invoice reads only other add ons would be 42lb injector and a $99 @ PCM4LESS Brian rules. Then again i got some good prices on parts and my machinest is not a thief. He did some real nice P&P on my heads for $370. Then there the 3.6k on blower option
chain gears $88
sir Ibeam rods $230
srp 8.50 to 1 $453
roller cam$240
lifters $135
Retainer locks $135
sfi flywheel $59.35
push rod $88
Gaskets $150
total2323.95
labor
3angle v/jo $125
surface $53.03
port polish $375
r&r pistons $52.56
boil block $35.38
Boring 145.44
in cam brgs $32.59
freeze plugs $25.25
bal v-8 $225
LG block *** $400
misc labor $80
Total 1538.84
Nope it came fully assembled STREET&STRIP machine shop in south florida. Lets just say i hit it off well with the owner Al from start he is a nice guy. He gave me cost on all parts(it has retail prices on invoice). They dont charg high prices anyway, he builds more big blocks and early v-8s60s70s than lt1s but i must say he did a damn good job as far as i can tell. S&R also built my brothers motor np there either, and his was way cheaper(88lx). They also let me come by every day or so to take a look at progress. Anyway i will go to him again.
tony said it would take at least 15k to break the 11 sec border, that 5k for internal engine and 5k for forced induction wouldnt be enough money to get low times.
budget 10s
complete forged 355 or 383 longblock
w/ heads and custom cam........................$5500-6000
12bolt, budget suspension........................$2500
clutch............................................ ................$500
Nitrous wet kit............................................$50 0
fuel pump, injectors....................................$400
dyno time.............................................. ......$300
thats about $10000 (assuming that you do your own labor)
capable of 10s all day long
FWIW, I made 411/385RW with less than 3 grand, on every engine mod/addon I had, headers included. As for suspension, I have Koni DA and stiff springs, so not exactly a drag setup. Grab a set of $50-$100 salad shooters and throw some slicks on there along with your 12 bolt, or do a budget stroker and maybe throw some nitrous on top of that. You could also consider a solid roller.
1000 different ways to skin a cat right.
Tunercat $89
Cable $65
1 hour dyno $100
Tunercat $89
Cable $65
1 hour dyno $100
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Jan 18, 2015 08:05 AM
guionM
14
Jun 19, 2002 08:30 AM
