$$$$ w/!egr and !air
Old Jun 15, 2003 | 09:44 PM
chevyboy_z28's Avatar
as far as buying block off plates and the other miscellaneous things i will need about how much does it cost to perform these operations ?
Old Jun 15, 2003 | 09:51 PM
FireAm94's Avatar
You don't really have to spend anything. Just use the lead EGR gasket as a template for a blockoff plate and cut one up. You can just disconnect the AIR pump and turn it off on the PCM....or all you have to do is plug the hole near the air filter.
Joe
Old Jun 15, 2003 | 09:56 PM
what do you mean turn it off on the pcm...how?
Old Jun 15, 2003 | 10:10 PM
FireAm94's Avatar
Errr...sry man....just turn off the air pump diagnostic so you don't trip a code....it will run fine but that service engine light is a royal PITA at night. You can kill it with LT1 Edit or Tunercat.
Joe
Old Jun 15, 2003 | 10:28 PM
or pcmforless maybe...this way i can have them kill the speed limiter, and do some other things for me (shhh its a secret ) all at the same time!
HectorM52
Jul 30, 2017 11:46 AM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
