Z06 clutch
Old 07-21-2003, 07:11 PM
Highlander's Avatar
Z06 clutch
Till how much rwhp a z06 clutch is good for??? will it hold a cam headers and 150 n2o shot??
Highlander is offline
Old 07-21-2003, 09:18 PM
dis3as3d's Avatar
Dont hold me to this but I rember seeing a post where a guy said he got 3 passes on the track with 150 shot and heads / cam work. The impression ive got is its good replacement for the stock clutch if you only have a few bolt ons and no dr's.
dis3as3d is offline
Old 07-21-2003, 11:46 PM
93TAWicked1's Avatar
I just toasted the clutch in my 01 which I read somewhere was the Z06 clutch (correct me if I'm wrong it was internet information) Makes sense though GM isn't into making multiple things hense the LS6 intake on 01 and 02 cars. Its a great deal for a daily driver that never races but I wouldn't trust it to anything more....although I do know a guy with a 400rwhp car that has it and holds fine.... I'm never that lucky
93TAWicked1 is offline
Old 07-21-2003, 11:57 PM
neat's Avatar
I smoked mine with a stock car and a 100 dry shot. I never launched with slicks or on the juice either. My advice is the money. Better to do it once, then half a dozen times. McLeod single or Cartek would be my recommendation for your mod level. I know they're expensive, but what ya gonna do?
BTW, the ZO6 clutch was the 2nd clutch I put in my 99 TA. The third was a McLeod single disk. I wish I had gone that route the first time. Good luck!
neat is offline
Old 07-22-2003, 12:35 AM
Highlander's Avatar
How much power does the single disc hold?? is it heavy??
Old 07-22-2003, 12:45 AM
The 1st replacement clutch wasn't a spec III carbon was it?? I just ordered one
Old 07-22-2003, 12:50 AM
Highlander's Avatar
I have a centerforce DF and so far so good with 600rwhp... but I am sure it will not hold a slicks launch...
Old 07-22-2003, 12:56 AM
Sparkz28's Avatar
maybe it was me?...I made three passes with my z06 clutch before it let go with a bang....I was spraying a 100 shot along with the mods in the sig..
I would not run that clutch again.....however..it was the best clutch GM made for the Ls1
I run a stage three spec now...its good for 600rwhp
Sparkz28 is offline
Old 07-22-2003, 01:56 AM
jd13's Avatar
Don't count on the Z06 clutch togive you anything special. If you want to add N20, I suggest atleast a spec stage 2 clutch. I've got a z06 clutch for now until I can mod other things. Once I'm done I'll be updating a few things (especially clutch for the nitrous) for the extra power I'm adding.
jd13 is offline
Old 07-22-2003, 02:20 AM
mr_muff's Avatar
if your not spraying off the launch or when changing gears, would the clutch really matter? isn't it disengaged? i never woulda thought it mattered unless it was being pushed in or whatever.
i can see if you had h/c and other bolt-ons cause the power is always there then working the clutch.
mr_muff is offline
Old 07-22-2003, 03:52 AM
DarkAngel SS's Avatar
What's the rating for the Z06 clutch as far as power goes?
Looks like its a good clutch for the street/bolt-ons, but will not hold the punishment of the strip/n2o?
DarkAngel SS is offline
Old 07-22-2003, 10:47 AM
Highlander's Avatar
Hey Dark... Welcome to the board... Newbie!! , I bet you want the z06 clutch??? Well... Forget about it!!!! Buy the spec 2. IT wont hold...
Ericksd
01-20-2016 06:07 PM
Mikes 1994 z28
10-10-2015 07:55 AM
Bxlt1
09-29-2015 03:18 PM
Ericksd
09-16-2015 07:08 PM
Quick Reply: Z06 clutch
