will 5.3 heads on my stock Ls1 increase horsepower
Old 06-08-2004, 04:22 PM
zo6vette's Avatar
if i bolt on 5.3 heads on my Ls1 with this increase horsepower?
zo6vette is offline
Old 06-08-2004, 04:58 PM
6speedZ28's Avatar
I believe to get any power increase those heads would have to be ported.
6speedZ28 is offline
Old 06-08-2004, 06:12 PM
MISOMWS6's Avatar
If they are just stock 5.3 heads it prolly won't do much, i'm pretty shure they will give you a slight bump up in compression, so you may see a small increse. I'm shure someone will know the exact compression ratio.....I can't remember it at the moment
MISOMWS6 is offline
Old 06-08-2004, 09:18 PM
Demon SS's Avatar
as a direct bolt on it is not worth the effort. it will raise your compression from 10.1:1 up to 10.9:1 so in theroy that would give you a slight more power all things being equal, BUT the 5.3L heads have a 1.89 stock intake valve while the 5.7L heads have a 2.00 intake valve so the 5.3L heads don't flow as well in stock form.
Now ported you have a different story. We have a project car with ported 5.3L heads and a largish cam (plus other mods) that runs 11.4's at 120mph in the 1/4(car is an M6). Car has not been dyno'd yet but we estimate it to be about 460rwhp
Demon SS is offline
Old 06-10-2004, 02:05 PM
Taspeed's Avatar
Demon is right. Take a set of 5.3's and have 2.02's put in on the intake side. That should get you some hp. Now optimally you would want to have some porting done, but in stock form I picked up about 20hp with unported 5.3 and a little valve work
Taspeed is offline
Old 06-10-2004, 07:17 PM
Demon SS's Avatar
Hey Taspeed, you need to send those 5.3's to me so I can work em over for ya, then you can go give Scott J. a run for his money
We do a killer set of 5.3L heads (or any heads for that matter)
Demon SS is offline
F'n1996Z28SS
08-23-2023 11:19 PM
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Quick Reply: will 5.3 heads on my stock Ls1 increase horsepower
