widest tire?
Old Aug 27, 2003 | 11:01 PM
krillanaross's Avatar
Question widest tire?
can i fit some 315's on a 9.5 rim? If not what is the widest tire i can?
Old Aug 27, 2003 | 11:23 PM
SLOW_SS
Guest
Posts: n/a
Re: widest tire?
It will fit, BUT, you will be putting yourself in a very dangerous situation. The sidewalls won't be able to flex and will cause a blowout under duress.
I wouldn't go any larger than 285s.
Old Aug 27, 2003 | 11:50 PM
JaysGone's Avatar
In 1 word. NO. Get 11inch rims if you want to go with that size and get a BFH to whack the inner wheel wells where it WILL rub and a BIG aluminum bat to roll your fender edges up. Been there done that on other f- bodies Ive owned. No really good reason to go over 285s
Old Aug 28, 2003 | 12:17 PM
Lan01z's Avatar
285 is the max for a 9.5"
Old Aug 28, 2003 | 06:47 PM
chpmnsws6's Avatar
285 is the biggest i c but now i got a ? to ask.
So wuts the smallest i can put on the 9.5 inch rim then? (looking for a front tire)?
Old Aug 29, 2003 | 09:03 AM
IrocManiac's Avatar
You could put some 245's on a 9.5 inch rim I've done it without any problems...just outta curiosity why would you want two different sizes front/rear? I get the same all the way around and always have makes for a little better treadlife when you can rotate them at all four corners.
Old Aug 29, 2003 | 01:19 PM
Lan01z's Avatar
Definitely get the same size all around. You have to be able to rotate these tires! especially the front ones because they wear out on the outsides really fast
Old Aug 29, 2003 | 02:22 PM
KwikistZ's Avatar
NO! You just turn too dayum hard
Old Aug 29, 2003 | 02:23 PM
Lan01z's Avatar
arrrrrgh!
Old Aug 29, 2003 | 05:25 PM
chpmnsws6's Avatar
i don't put my front tires in the back. the back tires are gonna be 555r's and the front are gonna be the cheapest, hardest, easiest rolling tires they make for less rolling resistance. we also get new tires once a year
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Slayer
Jul 4, 2015 03:06 PM
