just bought a lq4 block....question
Old Aug 29, 2003 | 11:41 AM
vz125dude's Avatar
i'd like to see somehwere between 550 and 600 out of this motor. what would be the most cost effective way to achieve that?
Old Aug 29, 2003 | 12:46 PM
Beast96Z's Avatar
I'm assuming you mean "fly wheel HP". If so, bore and stroke to around 427 CI, get a big cam, and some stage 3 heads. This will put you in the FWHP range you are looking at. If you want RWHP, do the same and add the No2.
Old Aug 29, 2003 | 03:13 PM
vz125dude's Avatar
yes i do mean flywheel horse power. could i use a stock ls1 crankshaft in this block with that type of hp?? 550-600 and which stage 3 heads would you recomend?
Old Aug 29, 2003 | 04:19 PM
Beast96Z's Avatar
Did you buy a complete short block? I'm not sure if the LS-1 crank will work or not. If you are going to stroke it, the stroker kit you buy will come with a forged crank, rods, piston etc... As for heads, It just depends on the amount of money you have to spend. MTI, Absolute Speed, and GTP are a few of the best.
Old Aug 29, 2003 | 05:24 PM
vz125dude's Avatar
i would like to se 427 ci out of the block, what stroke and bore would that be. the lq4 block is already 6.0liters by the way. and yes its just the bare block.
Old Aug 29, 2003 | 05:52 PM
Beast96Z's Avatar
MTi uses a 4.060 bore and a 4.125 stroke to equate 427 CI. They sell the short block including 6.0 block machined and assembled for around $6700. The stroker kit should be around 1/2 that.
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Mar 25, 2015 12:09 PM
95chwagon
Feb 28, 2015 12:02 PM
99TransAmWS6
Jul 26, 2002 03:18 PM
