Where do I jack up the front of my LS1?
Old Aug 7, 2003 | 02:04 PM
LS1-Maniac's Avatar
Were getting ready to install my headers on my Hawk and I need to know how to properly jack up the front of the car. The back you jack up on the rear-end I believe but I have no idea where to jack up the front. Also, where is the best place to put the jack stands during a header install? Thanks
Old Aug 7, 2003 | 02:06 PM
Constrictor98TA's Avatar
I jack the front of my car up by the frame behind each wheel, and place the jack stands either on the lower control arm, or the engine cradle (K-member). Both work fine.
Old Aug 7, 2003 | 05:19 PM
Chrisz24's Avatar
for me I have to drive up on bords so I can put my floor jack under cuz my jack doesent go low enough.
When lifting the front I usualy lift in the front center , it is sorta a heavy duty bar like thing under the engine and has worked fine up to this point.
Jack stands I put behind each wheel, make sure you get the frame and not the tab where the fenders connect with 2 screws
CGM2010CAMARO
Apr 7, 2015 07:44 PM
akwa
Apr 5, 2015 05:09 PM
BigWil
Mar 29, 2015 12:24 PM
