where can I get SSRA?
Old Feb 26, 2008 | 08:55 PM
Z28luvr's Avatar
Where do people usually get their ssra? From a vendor on this site? Elsewhere? Also, how much can I expect to spend on it? Thanks!
Old Feb 27, 2008 | 07:27 AM
teke184's Avatar
www.lmperformance.com
don't know the current price
Old Feb 27, 2008 | 07:36 AM
AL SS590 M6's Avatar
Moderator
$189.99
Old Feb 27, 2008 | 05:42 PM
Z28luvr's Avatar
thank you!
Old Feb 27, 2008 | 08:34 PM
Ripper415's Avatar
i've had one for about a year now and it was worth every penny
Old Mar 5, 2008 | 12:42 PM
3rdgentug's Avatar
is there much difference between fast toys ram air and his one?
Old Mar 6, 2008 | 07:10 AM
Moderator
Many many differences. The FTRA is steel and stays close to the radiator so that it can bolt to the lower rad support and it has no lower scoop.
The SSRA is welded plastic and it angles away from the radiator towards the front of the car then enters the bottom scoop that is screwed to the front facia.
IMO the FTRA has a better chance of causing over heating problems due to being closer to the rad. The SSRA has a better chance of scooping water up off the road if your not careful. It does come with a block off plate now that you can install in less than a minute if your going to drive in a monsoon.
Friscoz28
Nov 28, 2004 03:33 PM
T/A KID
Sep 12, 2004 02:46 PM
blackrat
Aug 3, 2004 05:15 PM
SS1LE02
Feb 20, 2004 10:42 PM
darrens99formul
Jul 10, 2003 02:57 PM
