where can I get SSRA?
Many many differences. The FTRA is steel and stays close to the radiator so that it can bolt to the lower rad support and it has no lower scoop.
The SSRA is welded plastic and it angles away from the radiator towards the front of the car then enters the bottom scoop that is screwed to the front facia.
IMO the FTRA has a better chance of causing over heating problems due to being closer to the rad. The SSRA has a better chance of scooping water up off the road if your not careful. It does come with a block off plate now that you can install in less than a minute if your going to drive in a monsoon.
