SSRA2
Old Feb 20, 2004 | 10:42 PM
SS1LE02's Avatar
SSRA2
I'm now selling the SSRA2 through my dealers. The SSRA2 is the SSRA without the scoop. The SSRA has two boxes. The one that sits under the air filter and the scoop that slides into it from underneath. The top box is very similar to the FTRA and SLP cold air kit. The advatages over the FTRA and SLP kits is that it's made of black ABS plastic which doesn't heat soak like metal, it angles away from the radiator more to allow air to flow to the radiator, only takes about 10 minutes to install if you've performed the FRA mod already, and no drilling needed like the other two. My vendors will sell them for $129. The two vendors that sell them on this board are SpeedSpecialty and Speed Inc.
