when racing whats the best way to launch an automatic LS1
when racing iam wondering whats the best way to launch an Ls1 automatic? how do u guys launch with your automatice LS1?
i have a 3400 stall, suspension work and drag radials so i can stall up to almost 2500 rpms off the line and then as soon i get outta the hole, hammer it....leaves with minimal chirp if at all...
with a stock car on street tires, id try powerbraking up just a bit to say, 12-1300 rpms and release the brake... if u spin a little, just wait until u grab and then hammer it....unless u have a lot of power upgrades, stock motor, stock geared cars wont usually break loose again afte theyve grabbed..
its tough to explain, ya just gotta practice ur holeshots....its easy after a few launches...fun too
I went to the track on wednesday n when I launched it at 1300 I ran 13.6 @ 104 mph with a .557 rt. The first time I went to the track I didn't stall it and ran 13.6 @ 103 mph with a .735 rt My 60' times r freakin killen me this is wut I need advice on how get better 60' times.
I've gained about a tenth on a second when launching with a slight brake torque. Around 1000 rpm, ASR off, trans in D, not OD. Stock car with stock programming. I race at Route 66 in Joliet. They usually prep the track really good for the sub 9 second cars, so my stock Z on street tires never has a problem with traction. Some say the computer adjusts better the WOT if you break torque. I don't know if that's true, I just know my launch is better, and my times are lower with a brake torque. I may not do it any more though. I bracket race, and I think I'm less consistent torqueing it up. Best advise I can give.....practice. Develop your own technique, and become good at it.
Best r/t non torque: .007
Best r/t with torque: .040
It's all how you see the lights.
Originally posted by chevyzman1998
yes, by trying to stall up a stock converter it heats up and will cause you to run slower 60' tomes
to get your best times on a stock converter with street tires youll need to stall it.if youre running DRs with a stock converter some people do well flashing their converter.heat your tires up too.
Just my $.02:
I usually pre-load the transmission before I launch, and while this may generate a little extra heat momentarily, I don't think it's gonna kill .1 - .3 seconds
. IMO, by doing this, there will be less sudden "shock" on the rest of the drivetrain, and I've cut better reaction times and 60' times this way...
Best R/T to date: 0.512 seconds
Best 60' to date: 2.053 seconds (not bad for 2.73's)
I've found that if I launch off idle, since I'm running the original street tires still, they're more prone to break loose and hurt my 60' times (and subsequently my 1/4 mile times).
To sum it up, I stall it when I'm racing seriously
. IMO, by doing this, there will be less sudden "shock" on the rest of the drivetrain, and I've cut better reaction times and 60' times this way...Best R/T to date: 0.512 seconds
Brake_L8
Jan 20, 2015 09:44 AM
