Wheel hop w/ 4.11
Old Jun 16, 2003 | 10:34 AM
BadAndy743's Avatar
Wheel hop w/ 4.11
I'm getting wheel hop like a **** on the 1st to 2nd shift. How do I combat this? Is this detrimental only to performance or could it stress something mechanically? Thanks
Bad Andy
Old Jun 16, 2003 | 11:59 AM
jd13's Avatar
Lower control arms and relocation brackets will help.
An adjustable torque arm would also help.
Old Jun 16, 2003 | 12:57 PM
rncotton's Avatar
My first night at the track after the 4.11 install, I got wheel hop on the 1-2, 2-3, and 3-4 shift. It was awful.
I kept dropping the tire pressure between runs and finally got the wheel hop to go away when I got to 24 PSI (Hot) on street tires.
I've got boxed LCA's being built by Spectacle Solutions right now.
Old Jun 16, 2003 | 10:34 PM
BadAndy743's Avatar
Why would I relocate anything? the car is not lowered, I don't really know if changing the pinion angle is a good idea. Hey Roger, I like my Spec Solutions STB and if he wants to get some experimental LCAs out for testing, I'd be happy to try them out. Its nice to seem their line of products expanding.
Bad Andy
Old Jun 17, 2003 | 12:20 AM
96LT14u2Nv's Avatar
yeah, u dont NEED relocation brackets. my buddies LS1 car was wheel-hopping BAD!!! we added a set of $80 Lakewood LCA's from summitt. they worked great!!!!
Old Jun 17, 2003 | 12:58 AM
AL SS590 M6's Avatar
Moderator
Bad Andy
LCA relocation brackets are also in racing called anti-squat brackets. Lowering the rear mounting point of the LCAs causes the force applied under power to push down on the rear axle in most cases eliminating wheel hop and increasing traction.
This does NOT change the pinion angle at all.
The torque arm alone is the controlling factor for setting pinion angle.
Old Jun 17, 2003 | 01:47 PM
rncotton's Avatar
Bad Andy
You've got an e-mail.
Old Jun 17, 2003 | 02:56 PM
Eric @ DMS's Avatar
I too would suggest LCAs and brackets to start. Looks as if everyone has covered that already
Old Jun 17, 2003 | 11:59 PM
Got-LT1's Avatar
You meant 4.10s right? There are no 4.11s for the stock rear of a Camaro. I also get wheel hop with my Z/28 and have been told LCAs are the way to go, In fact I am buying them tonight.
Old Jun 18, 2003 | 09:08 AM
Capn Pete's Avatar
I believe there are 4.11's available. I'm not sure if all companies make them, or only certain ones, but they are available. 4.11's use a 37 tooth ring, and 9 tooth pinion, instead of a 41 tooth ring, 10 tooth pinion.
Old Jun 18, 2003 | 12:58 PM
rncotton's Avatar
Oh boy ... here we go again.
Yes, there are 4.11 gears made for the stock rear. I have a set of Motive 4.11 gears. I counted the teeth myself to make sure.
Motive makes a 4.10 gear set, made in the USA. Motive also makes a 4.11 gear set, made in Italy. However, I think they use the same part number.
Why did I get 4.11 instead of 4.10? 'Cuz that's what the shop had in stock the night I went in to buy my gears.
Old Jun 18, 2003 | 12:59 PM
jd13's Avatar
To the above question about 4.11s:
Not long ago on this board or ls1tech, someone proved that some Motive gears listed as 4.10s were actually 4.11s. It was said that the gears that were made in Italy were 4.11s and the gears made in the US were 4.10s. According to that info I have 4.11s. *shrug* I dare you to find a noticable difference.
edit: Yikes, you posted that ^ right before I did. lol
Old Jun 18, 2003 | 03:27 PM
BadAndy743's Avatar
No problem JD, 4.11s are noticably stronger than 4.10s.
Old Jun 20, 2003 | 01:15 PM
Got-LT1's Avatar
I stand correted.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
