Whats Your Oil Pressure At???
Old Apr 20, 2003 | 07:21 PM
stik6shift98's Avatar
whats everyone oil pressure at....
1. at idle
2. at wide open throttle
let me know asap
thanks
Old Apr 20, 2003 | 07:37 PM
Ferocity02's Avatar
Idle: 45
WOT: 70 max
Old Apr 20, 2003 | 08:21 PM
thanks for the quick reply.....i think my cars @*&%ed
20 psi at idle
45 at wot
and it only has 28k miles.....either that or my gauge cluster is messed up
Old Apr 20, 2003 | 08:25 PM
#7's Avatar
hot @ idle a little over 40
hot cruising on freeway in 6th @58-60
hot WOT or any rpm increase@ 65 or so
cold 150* all numbers 10*+ higher than hot
Dont tell us what I think your experiencing Watch it w/that 98 man. Whats your pressures?
Old Apr 20, 2003 | 08:30 PM
Originally posted by stik6shift98
20 psi at idle
45 at wot
what is wrong?????
Old Apr 20, 2003 | 08:38 PM
#7's Avatar
20 psi at idle
45 at wot
Ive seen lots of time these kind of numbers come up to have others say thats still alright.Granted a little low and it is possible that the gauge is screwwed up being you have such low miles.Unless you've been abusing it the whole time. Pretty sure since you are getting a increase in pressure from idle to wot that the sender is working.
Old Apr 20, 2003 | 08:41 PM
i have an ses light on
im going to atap it right now......
it was at 40 at idle about two weeks ago....now
Old Apr 20, 2003 | 08:46 PM
cdmelcher's Avatar
worse shape then me...
I have posts on these concerns. Man, I do know mine will increase PSI with WOT to at least 60. And I spent time checking this out on the hiway around 2000 RPM I am steady at 44-45psi. AND I NEVER DROPPED TO 20 even at warmed IDLE.
BUT............am I doomed here, JEEZ and OIL PUMP is like impossible to install, like $ 700.00 from what GM tells me.
SOunds like BOTH of our PSI's are way too low.
Old Apr 20, 2003 | 08:49 PM
#7's Avatar
**** the oil pressure increasing from idle to operating or wot means the pumps still workin too,as far as the guage also I mean its giving you differnences in pressures?.But you know about the 98 oil pump thing...So maybe its starting to get fatigued? givin lower pressures.May be time to change it before **** happens let us know the codes you get sorry bud
Old Apr 20, 2003 | 09:04 PM
ya i know about the 98 pump thing.....thats why i have an A R E oil pump that i just got....after then it went low....
do u think that is because when they chnged the pump they put in some ****ty oil????
Old Apr 20, 2003 | 09:06 PM
WHAT ELSE COULD GO WRONG
now autotap wont connect to vehicle....im soooooo pissed right now
Old Apr 20, 2003 | 09:33 PM
2002Z28SSConv's Avatar
Your wife could run over an piece of crap in the road and put holes in your oil pan and transmission then bang up and bend everything else on the passenger side under carriage. Never ask what else can go wrong. ... Unless you really want to find out.
Let me get this right. You just changed your oil pump. Now it's reading low. You might have mentioned that in your first post. I'd say to consult the specifications of the pump. It might be rated at a lower pressure than the stock pump.
Old Apr 20, 2003 | 10:31 PM
its an A R E HIGH VOLUME PUMP
Old Apr 20, 2003 | 11:00 PM
High volume and high pressure are two very different things.
Old Apr 20, 2003 | 11:08 PM
true......anyone know the specs
