Whats Your Oil Pressure At???
hot @ idle a little over 40
hot cruising on freeway in 6th @58-60
hot WOT or any rpm increase@ 65 or so
cold 150* all numbers 10*+ higher than hot
Dont tell us what I think your experiencing
Watch it w/that 98 man. Whats your pressures?
Originally posted by stik6shift98
thanks for the quick reply.....i think my cars @*&%ed
20 psi at idle
45 at wot
20 psi at idle
45 at wot
worse shape then me...
I have posts on these concerns. Man, I do know mine will increase PSI with WOT to at least 60. And I spent time checking this out on the hiway around 2000 RPM I am steady at 44-45psi. AND I NEVER DROPPED TO 20 even at warmed IDLE.
BUT............am I doomed here, JEEZ and OIL PUMP is like impossible to install, like $ 700.00 from what GM tells me.
SOunds like BOTH of our PSI's are way too low.
**** the oil pressure increasing from idle to operating or wot means the pumps still workin too,as far as the guage also I mean its giving you differnences in pressures?.But you know about the 98 oil pump thing...So maybe its starting to get fatigued? givin lower pressures.May be time to change it before **** happens
let us know the codes you get sorry bud
ya i know about the 98 pump thing.....thats why i have an A R E oil pump that i just got....after then it went low....
do u think that is because when they chnged the pump they put in some ****ty oil????
WHAT ELSE COULD GO WRONG
now autotap wont connect to vehicle....im soooooo pissed right now
Let me get this right. You just changed your oil pump. Now it's reading low. You might have mentioned that in your first post. I'd say to consult the specifications of the pump. It might be rated at a lower pressure than the stock pump.
