Whats that on top of my Header?
Newbie question, What is the hose that connects to the top and fwd of my stock headers? I have a 02 Z so I wouldn't imagine it being EGR. Can someone please tell me what it is and if I need it when I order some JetHot LT's and can I remove it when I get LT's.
Thanks,
Travis
Thanks,
Travis
Thats your A.I.R. fitting. Connects to your air pump, pumps air into your headers...no reason to get rid of them really. It's emissions equipment so I wouldn't mess with it unless you don't have emissions
Do these take away HP and does anyone know if Jet-Hots come with AIR fittings? I'm not in an area that requires emissions so if I wanted to get rid of it how do I do it? Is there a tutorial somewhere?
not sure if the JHs come with or without emissions.
if they don't all you do is remove all the hoses, one from each side, and the hose running down behind the driverside headlight. the pump is located in there. i think you remove the headlight assembley and just remove the pump. or you could just leave it there, remove the hoses going to it and pull the fuse so it doesn't get power.
if the JHs do come with the fittings, you will need some block off plates (available through www.thunderracing.com for $18pr). just block the fittings off and remove the rest as stated above.
doing this will throw an SES light. you will need to have it programed out.
removing it DOES NOT affect hp at all, but i do think it will make your cats burn out faster...but you will probably not have any regardless...
on the same note-
having it hooked up and running doesn't cost you any hp either, it is more of a visual mod and a way to remove some clutter and weight off the car.
on the same note-
I dno if its true on our cars, I think it was just carbed cars
but if you romped on it and let it down rev a backfire in the exhaust would blow your muffler open....now if I could only remember which cars that happened too....
Victor Lamb
Aug 26, 2017 02:52 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
