what yr was LS6 intake standard on F's
Old Apr 21, 2004 | 06:33 PM
Ryanrabbie's Avatar
Was it '00 or '01 that the LS6 intake manifold was standard LS1 eqipment for the F cars?
Old Apr 21, 2004 | 06:37 PM
mullettour's Avatar
01
Old Apr 21, 2004 | 08:07 PM
Capn Pete's Avatar
Yup, '01 / '02 .
Old Apr 22, 2004 | 07:57 PM
joshp14's Avatar
Is there a noticeable difference between the 98-00 LS1's and the 01-02 LS1's? What are the diff. HP ratings?
Old Apr 22, 2004 | 09:28 PM
LetMeBurnU's Avatar
98-00 is rated 320 hp and 01-02 is rated 325 hp
Old Apr 23, 2004 | 03:14 AM
AL SS590 M6's Avatar
Moderator
Actually that's the SS and WS6 models. Zs and Formys are 305 and 310
Old Apr 23, 2004 | 10:04 AM
teke184's Avatar
the difference in the intake manifold is the 01+ flow better and do not come with provisions for EGR
Old Apr 23, 2004 | 01:17 PM
FLIPPINZ28's Avatar
ive heard 01 02 come with the ls6 intake no egr but have a smaller cam than the ones in the 98-00 not sure though someone will chime in though
Old Apr 23, 2004 | 01:48 PM
PhantomTA's Avatar
Moderator
correct.
Old Apr 23, 2004 | 03:11 PM
Capn Pete's Avatar
The valve lift for the '98 - '00 cam is something like ~.499", vs the '01 - '02 cam is around .478 - .479" lift, but the duration and LSA's are different..........lift isn't the only thing that makes a cam. The '01/'02 LS1 cam is supposed to be the same as the cam used in the 6.0L trucks!
Old Apr 23, 2004 | 09:07 PM
LetMeBurnU's Avatar
There it is....
Old Apr 25, 2004 | 10:22 AM
Ryanrabbie's Avatar
So why the cam change and EGR provision change?
If u take the non factory LS6 intake car and add it yourself, will it make more power than the factory LS6 installed cars with the ones with the bigger cam?
Is it worth the effort to change on the older cars?
Old Apr 26, 2004 | 12:25 AM
Moderator
The cam change was to do away with the EGR.
And yes it's worth it to change over on an older car. You can get one from SLP with the egr provivions.
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
