What will I loose if I remove the ABS
Old Aug 30, 2002 | 08:18 PM
z2894convertible's Avatar
Question What will I loose if I remove the ABS
I am not exactly for sure what the difference between an ABS car and non ABS car is. I think the ABS keeps the brakes from locking up if you have to slam on the brakes. Am I correct? The reason I am asking is because I found a 9 inch rearend that I want. Thanks.
Old Aug 30, 2002 | 08:26 PM
ratio411's Avatar
Post
I don't know a whole lot about it... but I do know the traction control works off of the ABS sensors.
Dave
Old Aug 30, 2002 | 11:25 PM
Klypto's Avatar
Post
abs just used the comp to VERY fast grim/un grip the wheel instead of just holding down, that makes it much harder to lock up the breaks and skid out...
cory
- 1998 Black Camaro A4 -
Audio -
HU: Kenwood KDC-316S
Speakers: Four Boston Acoustics RX67
Amp: 800W Neon 4Ch Bridged for 2
Subs: Two JL Audio 12W3D4
AOL/AIM: Binkyboy88
This is my AIM buddy icon:
http://www.angelfire.com/nb/corycamaro
Old Aug 31, 2002 | 02:43 PM
chrish's Avatar
Post
When a wheel locks up it can not carry any lateral or longitudinal force. This means that you will not have directional control with locked up wheels.
ABS releases the brake on a wheel for a split second if the wheel locks up. Thus the wheel can build lateral forces again and you can control the direction, in other words the car will remain controllable.
ABS does this individually for each wheel, so the car remains controllable even if you brake as hard as you can.
HTH
Victor Lamb
Aug 26, 2017 02:52 PM
guruerror
Jun 9, 2015 07:41 AM
KYWes
Apr 3, 2015 07:59 PM
squarehead
Jan 15, 2015 07:02 PM
ANDYZ28
Dec 29, 2014 09:13 PM
