What Valve Springs are these? (Help Identify)
Old Aug 25, 2008 | 11:28 AM
Mike96z's Avatar
I bought some heads, they have these dual gold springs on them, they look to be either Patriot Performance Gold or PRC springs. They are made by the same company I know but how am I to distinguish the two sets? Is there something in them that have a diff color? Im going to pull a spring and snap some pics, maybe I can find a local performance parts store who can match em. Any help is appreciated.
I found this info:
5. Patriot Gold Duals: See Crane and 921’s. The PP Golds come on all PP heads. PP are the only genIII spring setup to use the super 7 10* locks.
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
My Personal Indepedently tested PP golds:
seat: 143 lbs @ 1.800
open: 363 @ 1.200
coil bind: 1.060
Clearance: .140
spring rate: 367
6. PRC Dual Spring Kit: Kit comes with Dual springs, tit. retainers (using stock locks), seats, valve stem seals. good for up to .660 lift
seat : 140lbs
open: 390lbs
install : 1.800
coil bind: 1.07
1.290 O.D.
max lift : .660
matl : super pure chrome silicone
- PRC Platinum springs:
seat: 145# @ 1.7850"
open: 395# @ ?
PP, PRC, TEA, and all other "Gold" springs are all made from the same manufacture; Associated Springs. The differences are in the retainers and seat locators.
Here are pics of mine:
Here are manufacturer pics:
Patriot Gold
PRC
Patriot Extreme Dual Springs (silver inner spring/mine are gold)
So I see there is a diff in the locks, what will be the diff in the 10 degree versus stock valve locks?
Mike
Old Aug 25, 2008 | 01:14 PM
Mike96z's Avatar
found out they are PRC, you can tell by the size of the Valve locks, as pictured here, the Patriots have much bigger locks.
Old Aug 25, 2008 | 01:15 PM
Mike96z's Avatar
mine
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
