What it takes ls1 to break into 12s.
Old Mar 23, 2006 | 10:14 PM
pHEnomIC's Avatar
Previous owner of my t/a ran a 13.4, he said that was his only time at track and he wasn't experienced so there is room for improvement.
Car is a 2002 t/a m6 w/ 3.42's. 275 street tires.
Dynomouth exhaust, lid, slp maf, smooth bellows, slp bilstein/eibach suspension, 1le swaybars if that matters.
The track is still closed so I am practicing a little technique right now so I will be decent. I have a little track experience.
I will do some basic weight reductions, tb bypass, I have tubular lcas and phb to install soon.
Is it possible to break into 12s with this setup or will i have to get Long Tubes, ORY, and tuning?
Old Mar 23, 2006 | 11:07 PM
muraoka's Avatar
Re: What it takes ls1 to break into 12s.
i'd get some tires. good set of drag radials, and some practice. 12 sould be possible.what did it mph?
Old Mar 23, 2006 | 11:12 PM
FiefSS's Avatar
Its possible to hit a high 12 with that setup, drag radials will make it even more likely.
Old Mar 24, 2006 | 12:34 AM
V6toZ28's Avatar
Get rid of the SLP MAF ...
Old Mar 24, 2006 | 07:50 AM
Bayer-Z28's Avatar
The MAF is about worthless. No major power gain there. But that car is 12.5 something capable, bone stock w/ a good driver. I'd say the better tires and maybe an exhaust.. A set of LCA's would help too! Ehh...throw in a lid and filter too....
GMHTP Magazine tested a stock 02 SS and it did well... look it up..
Old Mar 24, 2006 | 10:14 AM
Greed4Speed's Avatar
The driver mod and tires
Old Mar 24, 2006 | 11:47 AM
00cls1camaross's Avatar
you can prolly break into the 12s stock with some et streets. i know a guy from down here who is 13.03 with et streets, no exhaust muffler, and a K&N
he was launching from 5k and his 10 bolt was fine
Old Mar 24, 2006 | 03:06 PM
scottslt1z28's Avatar
i wouldnt suggest anyone try that unless they are prepared to buy a 12-bolt.......
Old Mar 24, 2006 | 03:13 PM
Kraest's Avatar
Retired
All you need is some Nitto Drag Radials and you'll be well into the 12s with that setup as long as you can drive.
Old Mar 25, 2006 | 12:32 AM
robb4964's Avatar
I ran a 13.1 with lid,catback,FRA @109 MPH on street tires nursing it off the line with 2.3 60's.
With your mods 12's should be easy
Old Mar 25, 2006 | 12:05 PM
damn you guys are good drivers... i have only been driving since june
Old Mar 25, 2006 | 03:57 PM
robb4964's Avatar
Actually when I was pulling 13.1's I wasnt a good driver. I was a novice hence the horrid sixties. If I was a good driver I would have easily hit 12's with those traps.
Although I have advanced.
Old Mar 25, 2006 | 06:19 PM
JDMZ28's Avatar
It all depends on the driver and traction at your point. Friend of mine went 12.80's at 109. Stock except lid/ muffler. Auto.
If your clutch can handle sticky tires you could go 12's right now.
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 13, 2015 03:09 PM
Darth Xed
Jul 1, 2002 03:22 PM
