What springs to use with the LS6 cam?
Old Jul 14, 2003 | 12:11 PM
Mike94ZLT1's Avatar
Hey guys, what springs should I use with my LS6 cam? Can I reuse my stock rocker arms? And what kind of numbers should I be looking for after I'm done? (Also, do you think this can be done in a day?)
Old Jul 14, 2003 | 12:31 PM
Bone Maro's Avatar
LS6 springs will work just fine with the LS6 cam.
Yes, you can use your stock rockers.
Look for a 20-30rwhp increase with nothing else done.
Yes, it can be done in a day. 4-8 hours if you're doing it for the first time.
Old Jul 14, 2003 | 04:51 PM
jd13's Avatar
The ls6 springs are all you need, you could go better, but there is no need. Yes your stock rocker arms can be used, you could ugrade them if you wanted to, this would be a good time, stock retainers, and everything else can be reused.
You'll probably see 15-20 rwhp. The people that are seeing 30 out of it already have headers and most of the time a LS6 intake. It'll all catch up in the long run though when you get headers.
Old Jul 14, 2003 | 09:10 PM
ULTIMTEORANGESS's Avatar
everything said here is correct.i have ls6 springs with my cam and im ok.youll benefit greatly with headers as with any other cam.
Old Jul 14, 2003 | 10:56 PM
mr_muff's Avatar
whats bigger, ls6 cam or an ls1 hotcam?
and, what springs are the best springs we can put on our heads without them needing maching like ive read about some of the springs?
Old Jul 15, 2003 | 06:25 AM
hotcam is much better but ive heard about cars failing emmissions with this cam if its a concern which it is where i live.
Old Jul 15, 2003 | 07:00 AM
Bone Maro's Avatar
In addition, the LS6 cam is more "plug and play" and won't require tuning to run good. While, you'll benefit more from the HOT cam with tuning, and you'll throw misfire codes due to the lope from the HOT cam if the PCM isn't taken care of.
Old Jul 15, 2003 | 09:49 PM
mr_muff's Avatar
thanks guys, any info on springs? would ls6 springs do the job?
DirtyDaveW
Mar 15, 2015 07:01 PM
grabbem88
Feb 22, 2015 11:16 AM
alex5366
Feb 17, 2015 08:12 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
