What is the pcv ground strap for
Old Apr 15, 2009 | 11:19 PM
Jachin99's Avatar
What does the grounding cable going from the pcv valve to the TB? do?
Old Apr 16, 2009 | 12:27 AM
MikeGyver's Avatar
wtf?
pic?
Old Apr 16, 2009 | 05:13 AM
You would probably find the answer quicker on the LS1 Engine Tech forum. There is nothing equivalent on the earlier engines.
Old Apr 18, 2009 | 11:19 AM
bluz28's Avatar
I took mine off over a year ago when installing a catch-can, and it didn't affect anything that I'm aware of .
Old Apr 23, 2009 | 11:18 AM
blacknight's Avatar
I heard it just for keeping the pcv from freezing in freezing temps. Took mine off after it caused a vacuum leak. Don't need it here in Southern Ca.
Old Apr 25, 2009 | 12:31 PM
Jachin99's Avatar
How did it cause a vacuum leak
Old Apr 25, 2009 | 08:40 PM
Sunsetmaro's Avatar
broke mine off.
I broke mine off during my H+C swap. It doesn't affect anything...If you notice, it goes around plastic, so it really doesnt ground anything.
Old Apr 26, 2009 | 06:10 AM
AL SS590 M6's Avatar
Moderator
If you have a factory PCV valve it's steel and the strap goes around the valve itself so it definitely grounds the valve.
Old Apr 30, 2009 | 07:03 PM
DaddySS's Avatar
It's actually a heat synch to keep condensation from freezing the valve.
Old Jun 19, 2009 | 06:49 PM
FactoryZ's Avatar
After chasing my high-rev-gremlin, i discovered that this ground was also causing my vacuum leak. The metal piece that attaches to the rubber boot around that pcv valve, was sort of slicing the boot open. I discovered this after fiddling around the boot and feeling some oil oozing out of the spot where the metal connects to the boot. I just slid it out and unbolted it. Then wrapped the boot with some rubber tabe. No more Vacuum leak.
Thank goodness for this forum. I was worried about having removed it. Not anymore.
95chwagon
Oct 16, 2015 12:24 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
92_RS_305
Sep 8, 2015 07:47 PM
