What are LS1's supposed to weigh?
well, went with a buddy of mine to get our cars weighed in, my mustang tipped the scales @ 3300 with me in it(weighed 3320 last time, but got aluminum heads now and had about 1/3 of tank this time vs. about 1 gal last time). Anyhoo, my friends LS1 with him in it weighed in at a whopping 3800!! that was with a full tank of gas, normal racing weight is prolly closer to 3720 or so with less gas. his name on the board is RedBeast93Z. this is his sig:
99 trans am M6, Prokit, APHR, Weld in relocation brackets, LG motorsports front and rear sway bars with bushings, STB, Powerder coated black konig monsoon rims (17 x 9.5), SCC ram air hood, MTI clear lid, Mass air flow ends, ported throttle body, B&B catback exhaust with premium tips, Pro 5.0 shifter with lou's short stick, weld in subframe connectors
anyhoo, that thing is a pig!!
weld in relo brackets added weight
bigger sway bars added weight
STB added weight
subframe connectors added weight
bigger wheels and tires added weight
Why would it be heavy?
STB added weight
depending on options and mods thats about right..
my factory stripped car weighs 3470 with a full tank of gas. I only race with full tanks of gas. Doesnt make sense not to..
Figure 120lbs (15gal*8lbs per gal) would give my car 3350 with spare and all just hardly any gas...
I still have T-tops though.. without T-tops I can see an Fbod tipping the scales at 3200...
