What length pushrods do I need? (LS1)
Here is all necessary information (I think), I need to know what length of pushrod to order.
My heads have had the valves sunk .015" in the seat to aid in P to V clearance, and my valves are .070" longer than stock. Heads are milled <.005" (Clean up only)
By my figuring, my valves will be ~.080 taller than stock as assembled. (.015" + .070" - .005" = .080") Do I need longer or shorter pushrods than stock (7.400"), and why?
The rest of my valvetrain is as follows:
Comp "R" lifters
Yella Terra 1.7s
Comp 977 springs
2002 M6 Z28: Absolute Speed Stg 2.5 5.3l heads, G5X3, YTs, Comp "R"s, Hooker LTs, 3" duals w/ x-pipe, pulleys, full boltons, full suspension, Wolfe rollbar, Spec S3, Moser 12 bolt w/ 4.30s, and so on, and so on, and so on.....
2002 GMC Z71, 5.3, no mods....ever....I'm serious....
Comp "R" lifters
Yella Terra 1.7s
Comp 977 springs
What Joe said is correct. Referce also-
http://web.camaross.com/forums/showt...hreadid=159699
Moving to LS1 Tech. Thanks.
