What length pushrods do I need? (LS1)
Old Sep 30, 2003 | 06:44 PM
SPANKY LS1's Avatar
Here is all necessary information (I think), I need to know what length of pushrod to order.
My heads have had the valves sunk .015" in the seat to aid in P to V clearance, and my valves are .070" longer than stock. Heads are milled <.005" (Clean up only)
By my figuring, my valves will be ~.080 taller than stock as assembled. (.015" + .070" - .005" = .080") Do I need longer or shorter pushrods than stock (7.400"), and why?
The rest of my valvetrain is as follows:
Comp "R" lifters
Yella Terra 1.7s
Comp 977 springs
2002 M6 Z28: Absolute Speed Stg 2.5 5.3l heads, G5X3, YTs, Comp "R"s, Hooker LTs, 3" duals w/ x-pipe, pulleys, full boltons, full suspension, Wolfe rollbar, Spec S3, Moser 12 bolt w/ 4.30s, and so on, and so on, and so on.....
2002 GMC Z71, 5.3, no mods....ever....I'm serious....
Old Oct 1, 2003 | 03:46 AM
joeSS97's Avatar
The only way to know for sure is to use a length checking push rod.
Old Oct 1, 2003 | 08:30 AM
kmook's Avatar
Advanced Tech Moderator
What Joe said is correct. Referce also-
http://web.camaross.com/forums/showt...hreadid=159699
Moving to LS1 Tech. Thanks.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
