What Headers?
Old Dec 22, 2004 | 07:28 PM
  #16
96SFLZ's Avatar
Re: What Headers?
Originally Posted by Grave
I have the SLP headers... and so far they're really great. They're made of stainless steel *and* have a coating applied to them, something I haven't seen on any other header so far.
They're coated because they're 409 SS, not 304 SS (like Kooks, QTP, Dynatech...). 409 SS will eventually rust...304 SS will not.
Originally Posted by CRZYPWR
But other thing is ..maybe this is the reason why.. would there be a difference in SLP headers if u look at the year of the car ? Because when u want to order them .. for example LS1 Long tubes SLPs - same kind for same motor LS1 yet u have 3 different choices as far as eyar of the car.. 98 and 99 SLP will fit both 98 and 99 LS1... than 00 year will fit only 00 LS1.. and than 01 - 02 will fit both 01 - 02. So same kind of header yet in three diffferent choices depending on the year of the car... whats the difference ? its a same car..same motor.. same kind of headers..why 98 wont fit 00 but it will fit 99 ? I always wanted to know that ... anybody knows what the difference is between those years of ls1..as far as ... headers ?
IIRC, the only difference is the emissions hookups. The AIR tubes and EGR on the '98-'99s are a little different than on the '00s...the '01-'02s have the same AIR tubes as the '00 but no EGR.
That's the only difference, the headers are still the same...the cars are just a little different.
QTPs are on the expensive side but IMHO, they're well worth it (unless you're on a tight budget).
Old Dec 22, 2004 | 08:42 PM
  #17
BirchMan98z's Avatar
Re: What Headers?
FLP headers are a complete system though, including cats, offroad pipes to put in place of cats, y-pipe, headers. And EVERYTHING is coated. not just the headers. Worth the price in my opinion.
Old Dec 23, 2004 | 12:03 AM
  #18
Grave's Avatar
Re: What Headers?
I really dont know why ppl are complaining about SLPs ground clearance. I mean.. if u want to lower ur car yea they are way too low... i never lowered my car...i drive all over the place in the spring/summer and dont have one scrape on them ! But other thing is ..maybe this is the reason why.. would there be a difference in SLP headers if u look at the year of the car ? Because when u want to order them .. for example LS1 Long tubes SLPs - same kind for same motor LS1 yet u have 3 different choices as far as eyar of the car.. 98 and 99 SLP will fit both 98 and 99 LS1... than 00 year will fit only 00 LS1.. and than 01 - 02 will fit both 01 - 02. So same kind of header yet in three diffferent choices depending on the year of the car... whats the difference ? its a same car..same motor.. same kind of headers..why 98 wont fit 00 but it will fit 99 ? I always wanted to know that ... anybody knows what the difference is between those years of ls1..as far as ... headers ?
They'll fit... it's just on the 01-02' the EGR was deleted, so if you got, say... 00' headers (like me) you would have to get a block off plate for your EGR.
Or if you got the 01-02 headers for a 00' you would have to delete the EGR on your car.
Old Dec 26, 2004 | 12:51 PM
  #19
TXZ28LS1's Avatar
Re: What Headers?
why not try stainless works headers!! all stainless steel. i think its 800 with off road y and only 1100 with cats. thats a helluva lot better than paying 12-1300 bucks for catted kooks, and qtp and flp....i think someone even posted the hp they gained with stainless works headers...
Old Dec 27, 2004 | 04:41 AM
  #20
Re: What Headers?
actually, 409 grade stainless was chosen because it is LESS likely to corrode/rust due to its 2% molybdenum (moly) content. It was also chosen because its more easily welded.
And lets be honest, people are making exhaust components out of stainless steel (any grade) these days because stainless in general doesn't rust very easily, unless a catalyst is introduced (i.e. road salt, sea water, acid rain) hence the reason SLP uses 409--- the molybdenum content.
The ceramic coating certainly doesn't hurt either.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
