What does too much oil do?!?
Old Apr 28, 2003 | 06:55 PM
  #16
dmnall's Avatar
Capn Pete, you are correct, you check the oil when the engine is off, and check the tranny fluid (in an automatic) when the engine is running...
Old Apr 28, 2003 | 08:08 PM
  #17
Z-Attitude's Avatar
Originally posted by Capn Pete
I believe the "proper" amount of oil for the LS1 is 5.5 quarts isn't it? So running with 6 quarts should only be 1/2 over?
And psychocabbage: I don't think you check ENGINE oil with the motor running............that's only for checking auto-tranny fluid (unless there's something I'm missing..........but how would you get an accurate measurement otherwise? ).
I'll second that, you guys are a riot!
Old Apr 29, 2003 | 12:19 AM
  #18
zo6vette's Avatar
i just check my oil level is about half an inch pass the full mark?? would that be ok or do u guys think that is to much?
Old Apr 29, 2003 | 01:04 AM
  #19
Capn Pete's Avatar
Exclamation
That might be OK, but no further. Off hand, what's the distance between the "ADD" and the "FULL" mark......1"? So based on the fact that it's roughly 1 quart to get from the ADD to the FULL mark, then going 1/2" above full, would be about 1/2 quart above full, right? IMO, that's OK, but not really necessary.
Old Apr 29, 2003 | 01:27 AM
  #20
AL SS590 M6's Avatar
Moderator
As far as how to check your oil level.
Go out to your car and open the glove box and pull out the owners manual. Then READ it. There is a very specific procedure for checking the oil level in an LS1 motor. And it's not the same as we're used to doing. I won't try to quote it because if I get 1 word wrong you'll flame me.
Over filling the oil does 2 things:
1. It can put oil against seals and gaskets that weren't designed to hold back oil constantly. They're designed to hold back splashed oil only.
2. And by far the most important. Too high of an oil level will (as another has stated) allow the throws of the crankshaft to beat thru the oil. This action will aerate the oil which causes loss of oil pressure (air is easier to compress) and loss of lubrication of the bearing surfaces (air doesn't lubricate).
Depending on the engine and the type of usage sometimes extra oil is the lesser of 2 evils if you don't want to make the permanent changes to the oiling system that severe racing environments can require.
The best thing for the average Joe to do is to keep the level where the manual states. So if you use a bigger filter as I do then it takes more oil to maintain the correct level. It doesn't hurt anything as long as the oil level is kept in the proper running range. Again as stated in the manual.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
