valve spring not OEM
Old Oct 24, 2003 | 08:27 PM
2000zee28's Avatar
I am changing a bad valve spring on my LS1. I bought a OEM spring from GM (honeycomb type). I pulled the bad spring and found a second spring underneath. The retainers I have are much larger than the one needed for the honeycomb spring. So here's some thoughts.
1) The prior owner put aftermarket HP springs/retainers in.
2) The prior owner did this to match a aftermarket Hp cam.
I have no freaking way of knowing where the parts came from unless you bright guy's have some ideas!
The spring I need looks like it had a 1.840 installed height
and is a double spring with a 1.260 outside spring diameter
My thinking is SLP parts. Ron
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
