Using Heater hose to quiet ypipe/header hitting
Old May 28, 2003 | 10:58 PM
ZDriver96's Avatar
Ive heard that the LS1 guys use heater hose to quiet a rattle they get when the y-pipe hits the body of the car.
Well after my long tube install my passeger side long tuble is only 2 centimeters away from my A arm. Under somewhat of hard acceleration when the engine twists its self to the right and down the header goes right and down smacking the A arm.
I have two options.. I could grind some metal off the A arm and form a small groove so the header doesnt smack it or I can put heater hose inbetween the header and A arm..
Just wanted some input from the LS1 guys who've used heater hose to quiet there problems.
Old May 28, 2003 | 11:09 PM
BandDirector Blk98ZM6's Avatar
Most of us using the heater hose use it to fix the y-pipe banging on the floorboard. If your headers are too close to the K-member, then the most common fix for that problem is to grind the K-member down a little...I guess you could try heater hose 1st though.
Old May 29, 2003 | 11:02 AM
stik6shift93's Avatar
Are you sure it's not just hitting the floorboard? I've never heard of a problem with clearance with the a-arms, what kind of lts are you running?
Old May 29, 2003 | 11:20 AM
Ryuhei's Avatar
When I had MAC headers the Y-pipe was banging the floor board on hard acceleration. I had the shop bend the Y-pipe down a little bit and that completely took care of the banging. That might be an option. If the headers are hitting the A-arm, you can grind it down, or you can buy after market stuff from BMR. That would be pricey, but most people have more money than I do
Old May 29, 2003 | 12:01 PM
mw02's Avatar
I consider jb weld with a peice of heater hose the ultimate exhaust bang mod.
Old May 29, 2003 | 02:47 PM
ZDriver96's Avatar
Which part of the Y pipe hits the floor board exactly? After they come together or before on the passenger side header connection... ?? Ill check there too then.
I have Jet hot long tubes. There looks like a dents on one of the tubes (passenger side) thats hitting the A arm. It could have happened on the install of the headers though.
But heater hose is a great mod for ridding your car of exhaust rattles then?
Old May 30, 2003 | 09:45 PM
The Y-Pipe banging usually happen right next to the 2nd fitting on the driver side. There's bracing for the floorboard along with a shield for the fuel lines that hangs a little lower than the rest of the floor board, and that's where the banging usually happens. Yes, heater hose is a good fix AFTER you've loosened the header, placed a 1" block of wood at that spot and then re-tighten everything. Remove the wood and you should have about .75" of clearance and then put the heater hose there just to make sure.
Good luck!
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
