Ultimate LS1 Heads (apparently)
Old Aug 26, 2004 | 05:17 PM
  #16
Beast96Z's Avatar
Re: Ultimate LS1 Heads (apparently)
Originally Posted by AL SS590 M6
That being said I'd have to be pretty serious about spraying hard or big boost before spending the extra on AFRs when the TEA LS6/6.0 heads would flow the same.
Well, with that, the AFR castings are cheaper than LS-6 castings so......From what I was told, the LS-6's have to have the seats replaced with larger ones for the 2.05 valve to fit. Cost $125. Then you have to have new bronze guides installed. Cost $100. The AFR castings already come with these parts, so that is another $225 bucks saved over an already more expensive LS-6 head. So you get a better head for cheaper with the AFR as cast version.
Old Aug 27, 2004 | 11:30 AM
  #17
Jay3274bbl's Avatar
Thumbs up Re: Ultimate LS1 Heads (apparently)
This is a great thread on the AFR's
http://www.ls1tech.com/forums/showthread.php?t=208468
Old Aug 27, 2004 | 03:49 PM
  #18
BirchMan98z's Avatar
a set of stage IIR ls-6 MTI heads blows just about anything out of the water.
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
