Turbo ls1
Old Feb 9, 2008 | 12:45 PM
1977maroman's Avatar
Turbo ls1
I'm starting to build an ls1 for my '93 Z28. does anyone have any ideas where I could find information on a good cam I could run and what turbo would be best for the engine. I'm keeping the pistons, rods and crank the same and plan on running low amounts of boost, but have no idea about cam specs for a forced induction engine.
Old Feb 9, 2008 | 11:49 PM
Kraest's Avatar
Retired
I'd switch to a set of 6.0L 317 casting heads to lower the compression to around 9.5:1 and run a cam on a 214-220 intake and 220-230 exhaust on 114-116 LSA to be able to run a small amount of overlap.
Mike
Old Feb 10, 2008 | 09:04 PM
update
You said you wanted a small amount of overlap? Is that necessary for an engine with a forced induction system? Also, I don't have the money for a set of heads on top of the cost of the engine/turbo set up. I plan to just run the stock heads with a low amount of boost...4-6 psi was recomended.
Old Feb 10, 2008 | 10:58 PM
Kraest's Avatar
Retired
Yes, you want a minute amount of valve overlap on a forced induction system because there's no reason to blow boost out of the exhaust That's why you pick a smaller cam on a 114-116 LSA.
At 10.3:1 compression and hypereutectic pistons, you're on borrowed time with boost. All it takes is #7 to go lean one time and your motor is toast. The set of 6.0L 317 heads are only a few hundred dollars used and well worth the insurance. Or you can find someone to trade for the LS1 heads.
Mike
Old Feb 15, 2008 | 11:01 PM
Thanks, let me know if you see a cheap set of 317 casting heads by chance, lol.
Old Feb 16, 2008 | 04:27 PM
BadgeZ28's Avatar
another advantage for the 317 head is that they flow better than the stock LS1 heads. They are based on the LS6 castings with a bigger combustion chamber.
Old Feb 17, 2008 | 10:10 PM
New Era's Avatar
Is it front mount , or rear mount turbo ?
Old Feb 18, 2008 | 08:12 AM
Marc 85Z28's Avatar
Judging by the fact that you've got a 93 Z28 that you plan on putting a low boost turbo setup on an LS1 swap with stock internals, you're doing this on a budget. The stock LS6 cam works very well on low boost engines, and they can be bought MUCH cheaper than a very slightly more efficient aftermarket piece.
Old Apr 4, 2008 | 11:46 PM
still looking for parts :)
Yes this is most definitly a buget build, lol. After I pick up the engine I'm going for a set of the 317 heads and the ls6 cam, any other ideas?
The plan is to do a rear mount set up, but that may change as we begin to build.
Sorry about the delay in responce, I'll let you know as soon as we begin building.
Old Apr 7, 2008 | 10:46 AM
00TurboZ's Avatar
My specs for my cam and everything are in my sig.
Old Jun 11, 2008 | 01:26 PM
Nice
Killer set up man, only thing is I'm not to sure what a 255 intake pump is, lol. Let me know when you get a chance, thanks.
Old Jun 12, 2008 | 08:23 AM
AL SS590 M6's Avatar
Moderator
255lph intank fuel pump
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
