Transmission Drain Plug
Old Aug 5, 2003 | 11:38 AM
Black98's Avatar
I installed a drain plug kit from NAPA for my 4L60E Transmission Pan. There is a small leak and I drained the pan. Removed the pan and removed the drain plug, looks like I may have overtighten the nut and flared the teflon gasket. The gasket looks pretty cheap and if you get the nut really tight, do you need the gasket? If the gasket is needed, how tight do you tighten the nut? It doesn't take much to mess up the gasket.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
