Transmision question for the m6 guys
Old Jun 9, 2003 | 09:59 PM
smokin00z28's Avatar
Exclamation Transmision question for the m6 guys
As if I were going to launch in a 1/4 mile Im having a problem when I let off the cluth at about 2300 rpms I can here something clunking. is that associated with the torque arm or a transmission mount.
Old Jun 9, 2003 | 10:16 PM
2002Z28SSConv's Avatar
Most likely the tranny mount. But it should clunk just by hitting the gas. No need to drop the clutch at 2500.
Old Jun 9, 2003 | 10:21 PM
see I hit the gas comming onto the freeway one time and I accidently went from 3 to second gear (miss shift) the tires started to bounce I disenged the clutch and put it in the proper gear. I wonder if that tore the transmount.
Old Jun 12, 2003 | 02:59 PM
SSpray's Avatar
definaly not the torque arm. that would bang every time you speed up or slow down
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
