Top Speed
Old Oct 25, 2003 | 02:25 PM
JAG05's Avatar
Top Speed
what is the top speed of a 2000 camaro?
Old Oct 25, 2003 | 02:29 PM
chpmnsws6's Avatar
118 if the tires from the factory aren't Z rated
162 if they were
Old Oct 25, 2003 | 02:33 PM
JAG05's Avatar
My LT1 will do that.
Old Oct 25, 2003 | 03:32 PM
Z28CamaroGuy's Avatar
Are you talking about a V6 or a Z28 or a SS?
Old Oct 25, 2003 | 03:40 PM
chevyzman1998's Avatar
ive had my 98 to 160
holla if ya here me
Old Oct 25, 2003 | 04:01 PM
96SFLZ's Avatar
Point being?
Old Oct 25, 2003 | 05:35 PM
JAG05's Avatar
I thought the LS1 was faster. And i'm talking a z28 or SS they have the same top end.
Old Oct 25, 2003 | 06:12 PM
Capn Pete's Avatar
Same regardless of Z28 / SS / T/A / WS6. It's a factory set speed limiter, based on being equipped with Z-rated tires. You can remove the speed limiter with a programmer, and likely an LS1 would pull beyond ~165 mph and go faster overall than an LT1 powered car, but the real key is that the LS1 car can get to top speed a lot faster due to having more power.
Old Oct 25, 2003 | 06:31 PM
Fred94LT1's Avatar
Somebody told me the max MPH was limited to 159 by the computer setting on a LS1 powered car with Z-Rated tires? 162 works for me though. By the way what is the max mph for a 98 Mustang GT that hasn't been modded...? Just curious, Fred
Old Oct 25, 2003 | 06:53 PM
I got mine up to 145mph and it was still pulling pretty good, but I didn't max it out, and thats not stock either.
Old Oct 25, 2003 | 07:12 PM
unvc92camarors's Avatar
are you sure there's a mph limiter?
i know lt1's have an RPM limiter which causes the top speed to be around like 160 or somethin (check the lt1 tech, huge thread on it)
i would think they have no speed limiter like the lt1's (well, 255 or whatever which is unreachable anyways) but they would have an rpm limiter
anyone know for sure?
Old Oct 25, 2003 | 07:28 PM
Fred94LT1's Avatar
I know for sure with the stock computer settings my 94 Z28 had a 149 mph max programmed in from the factory. It wasn't until I purchased a HPP+ that I was able to reprogram the computer at that unreachable 255 mph.
Old Oct 25, 2003 | 07:53 PM
94ZRiCeKiLr's Avatar
a STOCK 98 GT is probably not gonna get near 145....
Old Oct 25, 2003 | 07:55 PM
why did u have a 149? this could not have been the fuel cut off because u CANNOT take that out with a Hypertech.... you need LT1 Edit....
what would be the reason for two speed limiters so clowe together???
Old Oct 25, 2003 | 08:02 PM
psychocabbage's Avatar
Yeah, my LT1 said 155... I think magazines back in the day were able to see 157 before the speed limiter kicked in..
