tinkerbell oil filter makes me nervous...
Old Sep 15, 2006 | 11:27 AM
SSCamaro's Avatar
Is there a bigger replacement for the rinky dinky one we have in there?
Old Sep 15, 2006 | 11:38 AM
PhantomTA's Avatar
Moderator
Re: tinkerbell oil filter makes me nervous...
Stock size is fine...
Old Sep 15, 2006 | 11:56 AM
SSpdDmon's Avatar
Some go to the larger truck filter.
Old Sep 15, 2006 | 12:13 PM
SSCamaro's Avatar
is the oil filter the same size and type as the older GEN I blocks?
Old Sep 16, 2006 | 07:06 AM
AL SS590 M6's Avatar
Moderator
no. If you want a larger filter then get a Mobil 1 M1-206 it's a little longer than the stock one.
Old Sep 16, 2006 | 01:58 PM
SSCamaro's Avatar
Okay, thanks. I want to put a high volume pump on and I would feel a little better with something big on there.. Why in the world did they go to a smaller filter???????
Old Sep 16, 2006 | 02:51 PM
blackrat's Avatar
i use the truck filter. supposedly it carries an extra half quart or something. had no problems, although it does hang an inch or so below the oil pan. still, wountle have to hit something extreme to damage the filter.
Old Sep 16, 2006 | 07:18 PM
Coolformula's Avatar
I used the bigger 2006 K&N filter. The stock one looks so tiny. What I dont' really understand is I used the big filter on my LT1 too and its still twice the size of the big filter onthe LS1..the filter for the LT1 is HUGE by K&N.
Old Sep 16, 2006 | 07:28 PM
SSCamaro's Avatar
Blackrat, is the truck filter you speak of the same one Al is talking about? If not, whats the truck filter number? Thanks.
Old Sep 16, 2006 | 07:37 PM
SSCamaro's Avatar
Given two choices, I would rather just find a bigger filter. Its too tight in there to try to dig up space for more stuff, although I am sure one can find some room fo rthe relocated filter.
A bigger filter has more filter area to catch more junk per pass
Old Sep 16, 2006 | 08:55 PM
johnny6's Avatar
Whats so bad about the stock one?
Old Sep 17, 2006 | 07:42 AM
Kwiksilverz28's Avatar
Nothing. People don't like the looks of it next to a Gen1 filter. Go pull one for a Honda or a Nissan. This is not meant to restart the age old debate, but in 3000 miles, the filters will not clog unless you are direct injecting dirt....
Old Sep 17, 2006 | 12:10 PM
SSCamaro's Avatar
I like the idea of having a bigger filter which helps reduce the preaasure area of the filter media itself.
Old Sep 17, 2006 | 08:41 PM
Maybe, but I still don't buy it. 3k miles on stock filters has gotten me to 150k plus on my cars. I have never had a lubrication failure, knock on wood.
Old Sep 18, 2006 | 10:30 AM
350 HRSS's Avatar
I agree, and I am sure GM tests all this stuff extensively anyway. I use the AC filter, and never had an issue.
