Ticking from Transmission?
Old Apr 22, 2003 | 07:16 PM
blkss01's Avatar
I hear a ticking sound that gets faster as the engine speed increases. Its not loud at all, but I can hear it when I bend down and listen by the transmission, I really don't hear it in the engine compartment. Please tell me it isn't piston slap...
Old Apr 22, 2003 | 07:36 PM
stik6shift98's Avatar
do u have enough trans fluid?
Old Apr 22, 2003 | 07:43 PM
blkss01's Avatar
Thats a good question.... I will check when I get my car back... Where is the dipstick, and the T-56's use ATF correct?
Old Apr 22, 2003 | 08:08 PM
hsyr's Avatar
Manual tranny's don't have dipsticks. They have a fill hole and a drain hole. To check look on the left side of the T-56 in the center about, take out the plug and stick your finger in it. If you get some fluid on it then its full, if not add some. Oh BTW why not change it while your at it?
Old Apr 22, 2003 | 08:25 PM
SFB767's Avatar
Does the noise sound like a "tink"?
My car tinks sometimes when I put it in reverse and when I'm taking off from a stop. The trans. guy says that when GM makes and welds the alum. shafts, sometimes some alum. shavings get trapped on the inside of the driveshaft forever. He says he sees it sometimes and it's nothing to worry about.
That might be what you're hearing.
Old Apr 22, 2003 | 10:07 PM
blkss01's Avatar
yeah that may be what i'm hearing... is there any aftermarket fluid that's recomended in the change? Or just use the OEM fluid?
Old Apr 23, 2003 | 06:02 AM
SFB767's Avatar
I'm not sure about the aftermarket trans. fluid, the trans. shop I get mine changed at uses Pennzoil and puts a conditioner in with the fluid.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
