throttle body bypass
Old Sep 1, 2003 | 07:14 PM
CHRISCAMARO's Avatar
anyone done this and what kind of improvements-if any- have you seen?
Old Sep 1, 2003 | 07:53 PM
psychocabbage's Avatar
It wont be worth the hassle..
Old Sep 1, 2003 | 08:28 PM
2000zee28's Avatar
I did the bypass mod. Not too much effort, 3/8 line 22-24 inches long and a barb fitting with 2 screw clamps. Can't feel any change in the car but the throttle body is a bit cooler. Like Psychocabbage said "not worth the hassle"
Old Sep 1, 2003 | 09:32 PM
DooSPX's Avatar
The mod was not ment be a SOTB gain... it is done to cut the hot coolent out of the TB, which heats it up, therefore heating up the incoming air. Which, everyone knows that hot air means less horsepower. The gain is much like smooth bellows... where "every little bit helps" comes into play. it takes like 10-15 minutes.
Old Sep 1, 2003 | 10:45 PM
Ferocity02's Avatar
"Every little bit counts."
I wouldn't go out and just do it, but if you are already working on the motor, go ahead and do it. I did it to mine when I had it all taken apart anyways
Old Sep 2, 2003 | 10:55 PM
Lan01z's Avatar
Do it man, do it!!!!!! I've got it and it took 3 minutes to install. The part cost only 15 bucks from bmr manufacturing.
(goin for the peer pressure effect)
Old Sep 2, 2003 | 11:39 PM
FastrDamnit!'s Avatar
Lightbulb
Would'nt really call it much of a "hassle." Granted you won't feel a difference but it should potentially free up a few hp, 2 maybe 3hp? takes about 20 minutes tops.
I used 5/16 hose about 2 1/4 feet and two worm clamps for each end (3/8 hose would probably fit better though).
I know that ws6.com dynoed before and after TB bypass on an LT1 and saw about 7rwhp, difference. I doubt we'd see that much of a gain on the average but I'm sure it would'nt hurt.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
