Those who use wheel spacers in the rear...
Old Oct 22, 2003 | 12:00 AM
br1ev8's Avatar
I am going to use wheel spacers for my rear y2k's. Problem is that the 5/8" spacers are too thick for the length of the lug studs on the axel. Do I have to put in longer lug studs? What did you guys do?
Old Oct 22, 2003 | 09:16 AM
wilbs600's Avatar
I ran in to the same problem when I put on my 17x11s in the rear. At first I used an acorn lug nut so it could grab some threads. I didn't like running around with them on and I was afraid of using them at the track because they were only on about 3 full turns. So what I did was put in new racing studs but you have to take the rear axles. If you know what your doing in your rear end then you'll have no problem but otherwise i would get some help. After I put the new studs in It was like normal but I also have about 3/4 of an inch of spacing probably on.
Old Oct 22, 2003 | 10:59 AM
br1ev8's Avatar
That's what I figured I was going to have to do, I just hoped there was some trick to doing it without removing them. Oh well, I need to change the diff. fluid anyway, I'll just do this at the same time. Do our 10 bolts utilize the "c clip" method of retaining the axels?
Old Oct 22, 2003 | 04:53 PM
Beast96Z's Avatar
Yes, they use the C-clip method. Undo the 8mm bolt, knock out the center pin, push axles inward, remove c-clips, and slip axles out.
Old Oct 22, 2003 | 06:20 PM
redz28kn3007's Avatar
You can get hub-centric wheel spacers in .75" and 1" thickness at
www.powertech.de
These are made for a 84 and up Corvette but fit the Camaro as well. They have pictures on the website as well, just find the "english" link on the site - otherwise it's in German.Hub-centric means that the weight/load is distributed to the axle using the hub and not the wheel studs. With these you could take the lug nuts off - car parked of course - and the wheel would still stay in place. This just as an example, not that anybody would ever do that....
Old Oct 22, 2003 | 06:23 PM
Oooups - forget the link above , it's in German only. Email me and I'll guide you through if you're interessted.
Old Oct 23, 2003 | 01:09 AM
br1ev8's Avatar
Beast96z--thanks, doesn't sound like too bad a job.
redz28kn3007--before I trouble you with translating the page, how much are these spacers? I searched the net and found many offerings for 4x4's in the $100+ price range just for a pair, and I really can't spend that.
Old Oct 23, 2003 | 06:54 PM
A good set of spacers like these are about 150$ incl shipping - a lot of money but.... these are good...
It's not easy to explain: these sit tight on your axle's hub and bolt to your original studs (new nuts are included), then the wheel mounts on the spacer on the spacer's studs. The spacer has a hub that the wheel then sits on.... brilliant design...
You can get spacers custom made on Ebay for 100$ but these are aluminum... the ones I got are stainless steel...
You might want to check vettebrakes - I think they're around Tampa - they sell spacers for the older vettes... they may be cheaper...
Old Oct 24, 2003 | 12:13 AM
br1ev8's Avatar
They sound really nice, but unfortunately I can't afford to go with these. I will just have to find a cheaper alternative. Thanks a bunch!
Old Oct 26, 2003 | 03:33 PM
ChevyMobbin247's Avatar
im using a 1inch spacer for the backs on my y2k's.. i had to cut off some of the original studs to make them work but its hasnt gave me a problem yet.. but then since i used a 1 inch spacer i had rubbing issues so i had to have my wheel wells rolled in..
check out my sig for pics..
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
derty
Aug 31, 2002 12:28 AM
