thermostat questions
Old Jun 12, 2005 | 11:46 AM
blu02byrd's Avatar
installing a powerstat 160 degree on my 02 trans am, it came with an o-ring gasket but where is the best place to put the gasket sealant on the actual thermostat or on the block and how much should i use. Also should i use my programmer to calibrate it for the thermostat or can i still leave the tune off till i want to use it?
Old Jun 12, 2005 | 12:37 PM
2001NBMZ28's Avatar
Re: thermostat questions
I just put a small amount of plumber's stem grease on the o ring on the tstat to make sure it seated properly while bolting it up - you can lower the fan temps whenever you want, it'll help in stop and go traffic.
grgguy
17
Feb 23, 2015 07:57 PM
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
