TFS LS2 225cc vs L92 heads
Old Mar 27, 2008 | 12:58 PM
  #46
Gripenfelter's Avatar
I'll ring him after work. Thanks.
Old Mar 27, 2008 | 04:11 PM
  #47
Kraest's Avatar
Retired
Originally Posted by Gripenfelter
Just emailed AFR. Thanks guys. Great thread. Lots of good info from all.
I'll update later with what AFR recommended.
Here's what they usually reccommend:
"Buy our $2500 heads!"
Seriously, though. GM Castings will work fine in nearly every application... even in forced induction, where you don't necessarily need a head that flows 320cfm @ .650. Even a stock 317 head will work wonders with a forced induction setup.
I made 514 rwhp with the converter unlocked with a 853 head that had nothing much more than a valve job and very low boost (stock pulley P1SC) on a stock cube, stock bottom end 346 on 93 octane with a 212/218 cam.
That translates to around 630-650 crank.
Mike
Old Mar 27, 2008 | 05:19 PM
  #48
LeeCTS-V's Avatar
Here it is:
Old Mar 27, 2008 | 06:18 PM
  #49
Kraest's Avatar
Retired
Originally Posted by LeeCTS-V
Here it is:
Yep. That's the one I thought it was. Dynapack.
Probably around 460 on a Dynojet 248.
Mike
Old Mar 27, 2008 | 06:44 PM
  #50
Me>you's Avatar
Torque curve is uglay
Old Mar 27, 2008 | 08:14 PM
  #51
Mike
Yeah but how much would it cost me to port some L92s + cost of heads?
Worst case scenario if I run out of cash I would still like a motor that runs strong NA.
Old Mar 27, 2008 | 08:33 PM
  #52
Kraest's Avatar
Retired
L92s are around $900 assembled. You don't need to port them for a blower setup. That's the beauty of it. Or you can pick up some 317 heads for $300.
You honestly need to decide what you're going to do and stop pussyfooting around You simply can't build a motor for both. 9:1 isn't going to run worth a **** NA and 12:1 isn't going to like boost.
Mike
Old Mar 27, 2008 | 10:35 PM
  #53
Mike
Yeah I know. I'm just trying to figure out how to build a daily driver beast whose cam lope won't rattle my fillings loose.
Old Mar 28, 2008 | 05:16 PM
  #54
Syn's Avatar
Syn
i should be starting my l92 iron 408 next weekend i got my heads bare for 300 shipped just gotta look around, valves for 150,tsp extreme gold springs for 225 so i got 675 into my heads
Old Mar 28, 2008 | 05:31 PM
  #55
Marc 85Z28's Avatar
Mike
Isn't that the one where they mount the dyno right to the vehicle hubs? Nothing like removing 100+ pounds of rotating driveline weight for a number... And where did he get "490+" from when the graph shows 480?
Old Mar 29, 2008 | 07:54 PM
  #56
LeeCTS-V's Avatar
Go back and look at the graph again - 490.8 hp. The has been since tuned again for a little more.
I do not understand why some people attack others for reporting what they've seen or heard. You could have said "I do not see 490+ hp on the graph."
Apparently the claim (cause I questioned this dyno too) is its tuned to perform like a dynojet. The car stock pulled 360rwhp on this dyno (which sounds about right for a dynojet).
So, even if it was "460 rwhp", would that be bad with a small cam ?
Also, the "ugly torque curve" - go back and look at the graph again. It reads 330 rwtq at slightly above 2000 rpms. You have to go look at the scale before you jump to conclusions.
-- Lee
Last edited by LeeCTS-V; Mar 30, 2008 at 09:02 AM. Reason: I appoligize.. I should have not done any name calling. I keep forgetting this is the internet and people are rude.
Old Mar 30, 2008 | 05:12 AM
  #57
AL SS590 M6's Avatar
Moderator
Man, what an ***. Go back and look at the graph again - 490.8 hp. The has been since tuned again for a little more.
I do not understand why some people attack others for reporting what they've seen or heard. You don't have to believe me, but why do you need to be a dick ? You could have said "I do not see 490+ hp on the graph."
-- Lee
Please no name calling. If you want to call him names, send him a pm.
Old Mar 30, 2008 | 09:25 AM
  #58
Marc 85Z28's Avatar
Both the graph AND the peak number readout show the same, 481.4HP. That 490.8HP you reference shows the limit of the scaling of the graph. And I would suggest you actually comprehend the "evidence" of your BS before calling names.
No kidding!
Old Mar 30, 2008 | 03:24 PM
  #59
slomarao's Avatar
just stay na. no reason to go FI with a larger cube ls2/3 setup. if you port those l92's and buy a fast 90 90 setup your not going to need the biggest cam to hit 500rwhp. Especially if you have them fully worked, Id say 540rwhp-510rwhp with 408 bottom end. Mainly depending on cam choice, but other things will play in too.
If thats not enough build a 427 -454, than you ll be right at 600rwhp withhout having to run a FI setup and still being able to run a ***** cam. When the itch for more power comes throw a 100-200 shot on it. 700-800rwhp should be enough to keep you happy. You ll never have all the bitchy tuning bs and retain some driveabillity.
Should you want more power its a button away.
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
BIGCOWL-IMP
Feb 7, 2015 06:10 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
