TFS LS2 225cc vs L92 heads
Old Mar 26, 2008 | 11:30 PM
  #31
Gripenfelter's Avatar
Originally Posted by LeeCTS-V
Friend has a 2006 LS2 powered Vette with L92 heads and a small cam (224/ .580 lift) and pulled 490+ RWHP. Car drives good down low. With those huge valves, you apparently have to watch the duration/lift. I've heard they are now offering them with smaller valves. He seems happy with the combo and uses it as his daily driver. Those heads come on all LS3 vettes - why would you think they would be "too big" for a 6L buildup ?
-- Lee
Thats awesome. Pretty much what I'm looking for NA. Do you know what his compression ration is or what cc the heads are? Would he still be able to run a blower or turbo later if he wanted?
Old Mar 27, 2008 | 09:05 AM
  #32
LeeCTS-V's Avatar
I believe they were stock (or close to) sized chamber (obviously milled after minor porting). Not sure I'd run any kind of boost on compression that high.
-- Lee
Old Mar 27, 2008 | 09:19 AM
  #33
Marc 85Z28's Avatar
Originally Posted by Me>you
Let it be known that valve cover issues are present when using ETP heads, you will also need a custom rocker pedestal, but that's only 100$...
ETP does make a nice head, but in addition to the rocker issue, you will need to pay a LOT of attention to the valvetrain. Most people seem to have trouble setting them up, and have poor results because of it. Pretend you're building a BBC and everything will work out nicely
And to making near 500whp with a 224 cam and L92 heads on an LS2 Don't think anyone else is going to duplicate that without a very friendly dyno. Now if the L92 heads are ported, that's another story, but by the time you port the L92s and getting them up to par you'd be better of with an aftermarket casting that has runner volumes that are 35cc less!
Old Mar 27, 2008 | 09:25 AM
  #34
Me>you's Avatar
-- Lee
Do you have access to the dyno chart, or can you at least give me the torque number??? I'm noticing a trend in my research, the L92's make decent top end, but are getting absolutely murdered in torque and midrange by the 225cc quality heads...From LS2 displacement all the way up to big cube strokers of 416ci and on...
One is brought to mine of a car that simply changed from L92 with L76 intake, more compression and a bigger cam vs AFR 225's with a smaller cam and less compression and the FAST 90mm...Results were +25hp and up 35tq, and the smaller heads had consistenly kept this advantage at every RPM...
However, the L92's are proving to be a great bang for your buck...Even untouched they get some decent numbers and are a pretty good choice, that is if all you care about is peak HP and don't know any better
Old Mar 27, 2008 | 09:27 AM
  #35
Any issues with the AFRs or L92s as far as valvetrain issues go?
Old Mar 27, 2008 | 09:28 AM
  #36
Me>you's Avatar
My thoughts exactly, i just didn't want to call him out and get an infraction...
And you're right about the ETP's, it's all in the details of the setup and valvetrain geometry for those heads...Every little thing is critical in choosing parts to work well together...
Which is why i still prefer the AFR heads over them, or the TFS
Old Mar 27, 2008 | 09:31 AM
  #37
Me>you's Avatar
AFR's, no...
L92's you need to run offset rocker arms...You can reuse your stock exhaust rockers, but will need the L92 intake rockers...Best bet is to just get some aftermarket rockers...
Old Mar 27, 2008 | 09:43 AM
  #38
Kraest's Avatar
Retired
I'm not going to completely throw up the BS flag on this one, but take that example with a grain of salt.
Way too much compression for boost and a dyno that reads a little high I'm sure.
If that's the car I'm thinking about, it was a completely custom 224/228 cam with "test" lobes, stage II ported/milled L92 heads, and dynoed on a Dynapack, which dynos higher than a Dynojet 248 partially due to the design of having to take the wheels off of the car when you dyno.
Gotta love the internet.
Old Mar 27, 2008 | 09:44 AM
  #39
Kraest's Avatar
Retired
You can call-out all you want if you have the knowledge to back it up. Flame fests aren't allowed, however
Old Mar 27, 2008 | 10:15 AM
  #40
Marc 85Z28's Avatar
AFR's, no...
Right, however on the L92s there have been more than a few instances of stock valves on stock engines breaking the heads off and trashing the engine. I read of a few of these cases on another board and confirmed it through a friend at a GMC dealer.
Plain and simple, if you're looking for good power NA or boosted, and want to do it with any kind of drivability and torque, you should look to an aftermarket head. The L92 initial purchase price is VERY misleading. In the end you're not saving anything. Again, remember, in the end the intake options for the L92 are very limited, and limiting.
Another option to add more confusion: There are several companies/porters that can make a 243 casting do things most would never believe. They are however, just as expensive as the aftermarket stuff
Old Mar 27, 2008 | 10:20 AM
  #41
Just emailed AFR. Thanks guys. Great thread. Lots of good info from all.
I'll update later with what AFR recommended.
Old Mar 27, 2008 | 10:23 AM
  #42
Me>you's Avatar
Forget email, just call and ask for Tony...
Old Mar 27, 2008 | 12:16 PM
  #43
Marc 85Z28's Avatar
AFR 235cc?
Old Mar 27, 2008 | 12:47 PM
  #44
AFR 235cc?
235? Huh? What? Did I miss something?
Old Mar 27, 2008 | 12:51 PM
  #45
Me>you's Avatar
You have to go straight to the source for their secret work...Like i said, give tony mamo a call
