Temp still says 210
Old Jul 15, 2005 | 10:40 AM
CDZ28's Avatar
Temp still says 210
Sorry i think this is a repost but i'm at work and don't have time to look.... Ok so i put in the Hypertech 160 thermostat but my temp guage still reads 210. Can some one tell me why that is??
Old Jul 15, 2005 | 11:22 AM
Kraest's Avatar
Retired
Re: Temp still says 210
Fans come on at about 220ish.
You won't see a decrease in temp until you get your fans reprogrammed.
Mike
Bert02SS
Guest
Posts: n/a
I've learned from this board that the temp gauges are not what they seem to be, i.e. a true calibrated gauge. Others will have better info, I hope.
Old Jul 15, 2005 | 11:44 AM
2001NBMZ28's Avatar
The '99 and up F-body gauges all read that way. I have a 160 and fans set to come on sooner and mine does the same thing.
Old Jul 15, 2005 | 01:19 PM
teke184's Avatar
98 was the last year of that actual functioning temp guage. after that they put in the dummy guage. it reads the same temp over a 50deg range
"You won't see a decrease in temp until you get your fans reprogrammed.
i hate this piece of advise...cause for the most part it's wrong.
sitting in traffic or running in the staging lanes are the only time you reprogrammed fans will make any difference. in traffic who cares about that extra 5hp you get from a lower temp. factory settings are sufficient.
any time you are moving there is air going over the radiator, and the fans probably aren't on. i never had a reprogrammed fan and consistently ran 170 in my LT1 and LS1 with lower stats. and that was even in mild traffic, in south florida heat.
Old Jul 15, 2005 | 01:32 PM
Bert02SS
Guest
Posts: n/a
So . . . the '99+ temp gauges read 25 degrees +/-?
Old Jul 15, 2005 | 03:06 PM
Kraest's Avatar
Retired
My gauge read 210 until I got my fans programmed. After the reprogram, my gauge reads 180 all the time. And that's verified both analog and digitally. I have no idea what the rest of you people are talking about. Maybe the Vette temp gauge is superior?
Mike
Old Jul 15, 2005 | 04:03 PM
2001NBMZ28's Avatar
With a scanner at the first mark on my gauge the ECT is 141, once it settles just below 210 it reads 185 - at idle with the AC off. It'll go above 210 if you start overheating, not sure at what temp it starts moving again is though.
Old Jul 15, 2005 | 05:05 PM
Greed4Speed's Avatar
Mine sets right below the 210 mark now w/stock Tstat and no tune etc.
Old Jul 16, 2005 | 05:24 PM
CDZ28's Avatar
Thanks alot guys..........I was looking in to getting the program from EFI LIVE i think the fans can be programed with that....Does any one use EFI LIVE? And if so what do you think???
Old Jul 17, 2005 | 09:05 PM
SpeedDemon02SS's Avatar
I have a predator and i think it works great. even picked up .2 at the track. but then i burned out my clucth...sad...
Old Jul 18, 2005 | 06:06 AM
lt1camaroman93's Avatar
i've seen all the way up to 234* engine temp with the guage still sitting right below 210.. Gotta love those accurate guages.
Old Jul 18, 2005 | 08:09 AM
there idiot gauges...the tack and spedo arn't even that accurate!
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
