Temp still says 210
Temp still says 210
Sorry i think this is a repost but i'm at work and don't have time to look.... Ok so i put in the Hypertech 160 thermostat but my temp guage still reads 210. Can some one tell me why that is??
Re: Temp still says 210
98 was the last year of that actual functioning temp guage. after that they put in the dummy guage. it reads the same temp over a 50deg range
"You won't see a decrease in temp until you get your fans reprogrammed.
i hate this piece of advise...cause for the most part it's wrong.
sitting in traffic or running in the staging lanes are the only time you reprogrammed fans will make any difference. in traffic who cares about that extra 5hp you get from a lower temp. factory settings are sufficient.
any time you are moving there is air going over the radiator, and the fans probably aren't on. i never had a reprogrammed fan and consistently ran 170 in my LT1 and LS1 with lower stats. and that was even in mild traffic, in south florida heat.
My gauge read 210 until I got my fans programmed. After the reprogram, my gauge reads 180 all the time. And that's verified both analog and digitally. I have no idea what the rest of you people are talking about. Maybe the Vette temp gauge is superior?
Mike
Mike
Originally Posted by Bert02SS
So . . . the '99+ temp gauges read 25 degrees +/-?
Thanks alot guys..........I was looking in to getting the program from EFI LIVE i think the fans can be programed with that....Does any one use EFI LIVE? And if so what do you think???
