teflon tape on knock sensor/stop KR
Old Oct 13, 2003 | 04:07 PM
Keiii's Avatar
I was told that some people have put teflon tape
on their LS1's knock sensor to aid in reducing KR.
Would that be a mistake to do or does it work?
Old Oct 13, 2003 | 06:53 PM
Kevin Blown 95 TA's Avatar
I would bet that how tight it is makes more difference than what you seal it with. It is going to grind its way thru the sealer to ground at all the high spots anyway. With pipe dope or teflon tape, if it is loose, it will probably be less sensitive. The only real way to tell would be with an o-scope.
Old Oct 27, 2003 | 11:38 PM
VeryBad's Avatar
I have heard that teflon tape on the can cause a KS code to be thrown causing a poor ground connection.
Gordon
Injector Cleaning & Flow Testing
http://www.witchhunter.com
Old Oct 28, 2003 | 05:37 AM
The response of the knock sensor to Teflon tape on an LS1 motor would best be asked in "LS1 Tech".
Moving it there......
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
