stroked ls1
Old Mar 20, 2005 | 10:21 AM
ironexecutioner's Avatar
stroked ls1
I was wondering if anyone could give me some dyno and track results on their stroked ls1. Also plz include what you have it stroked to. If anyone has results for an ls6 motor in a 98 camaro as well that would be appreciated. Thanks
Old Mar 21, 2005 | 07:57 AM
rossafenton's Avatar
Re: stroked ls1
what does "stroked" mean?
Ross
98 SS
Old Mar 21, 2005 | 11:28 AM
teke184's Avatar
Re: stroked ls1
stroked refers to increasing the distance the piston travels in the cyliinder in order to increase the displacement of the engine.
it is typically done by adding a different crankshaft.
you usually hear "bored and stroked" in which the diameter of the cylinder as well as increasing the lenght of the stroke. both of which increase the displacement of the engine.
take a standard small block 350, put a crank from a 400 small block and bore the cylinders .030" wider (or is it .060"... ) and you have the common 383 stroker engine.
there are way to many variable with stroked engines to get an idea of power and times.
and there isn't much difference between the LS1 and LS 6 block to make one have a significant hp advantage.
Old Mar 21, 2005 | 01:34 PM
Re: stroked ls1
So your recommendation is stroking the ls1 as apposed to buying an ls6?
Old Mar 21, 2005 | 07:03 PM
Reznor's Avatar
Re: stroked ls1
6.0L iron block twin turbo is what you need.
Old Mar 22, 2005 | 07:15 AM
teke184's Avatar
Re: stroked ls1
"So your recommendation is stroking the ls1 as apposed to buying an ls6?"
if you already have the ls1 block...yes
there is very little difference...at least to warrent buying a new block...unless yours is dead.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
