Stock tailpiping for dual duals?
Old May 26, 2003 | 11:13 PM
3.8knightrider's Avatar
I'm planning to put a dynomax super turbo on a 2001 V6 camaro convertible with the SLP dual dual tips. I'm missing the tailpiping. Approximately how long should it be? I want it pretty visible or at least like the stock length on a SS. Or should I just go to the muffler shop and see what they got? Thanks
Old May 27, 2003 | 01:32 PM
OK, now I have another question. My stock setup is the single outlet muffler. I would need an additional hanger for the second pipe on my new setup correct? I assume the muffler shop would drill in the right place, but is there any parts I should warn them about? Thanks.
Old May 27, 2003 | 07:54 PM
redz28kn3007's Avatar
Changing from a stock muffler to a dual tailpipe setup is easy, you can use the orig. hanger on the driver's side - there's no addistional hanger on the passenger side. The super turbo muffler sounds pretty good on the V6 - we have it installed on my wife's Camaro. Our Dynomax has two outlets on the driver's side.
When I tried to find a muffler shop to get it installed I was told it would be about 100 bucks plus tailpipes - forget that ! Go to ebay and buy a flux core wire welder (no gas required) and build your own setup, I only paid 180 $ incl shipping for mine and I used it a lot. Once you figured the welder out you might want to change your tips from time to time...
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
turbo_Z
Aug 19, 2002 10:50 PM
mysticslp2002
Jul 29, 2002 02:03 PM
